When I got on here people told me that the SG had WDR and that it was the same as HDR. I then expected the cam to take two images with exposures a few stops apart and then recombine the images to boost the low light areas and dull the bright ones.
Being that you're picky about terminology, that is NOT what HDR is. That is only one method for creating an HDR image. (HDR is the result, not the process.)
High Dynamic Range means... a high dynamic range. It's actually a confusing term, because it doesn't specify a relationship. High dynamic range compared to what? Compared to most color film photograph, black and white film photography is HDR.
In the digital world, "HDR" usually indicates an image/sensor that has a range greater than 8 bits of luminosity. Compared to an 8bit CCD or CMOS sensor, a 10bit (or 12 bit) sensor could be called "high dynamic range."
When you take two 8 bit digital images that were taken of the exact same image, but one light stop apart, and combine them using the HDR functionality in photoshop, you also have an HDR image.
In both cases (>8 bit sensor or combining multiple 8bit images), the result might be HDR, but most processes have to compress the luminosity data down to 8 bits for display or printing on consumer displays/printers.
So, what the GC does can be called HDR, even if the result is reached with a different process than what you're accustomed to.
EDIT: Please accept my apologies in helping to drag this thread so far off topic...
