A couple of frames contrasting center weighted vs average AE. These really serve no purpose other than to give people an idea how they might look. The center weighted, in theory, should base the exposure level on the area around the center of the frame (which is black asphalt here) while the average tries to take the entire frame into account.
So, again in theory, the center weighted can overexpose or underexpose if the center area is dark or light (respectively.) The idea is that the most important part of the image is near the center, so tries to ensure "perfect" exposure for that. If the center is dark, the entire image is lightened to compensate (and if the center is bright, the entire image is darker.)
First the center weighted:
Followed by average (if you check the timestamps, you'll see that the images are within seconds of each other):
What I'm not understanding is that the "center" AE option appears to be doing odd things with the AE. It's not just shifting the EV up or down based on the brightness at the center of the image. The clouds in the sky are blown out, which suggests that the EV was set positive. However, at the same time, the black dashboard appears DARKER in the center weighted, suggesting that the EV was set negative. Being that both of these can't happen at the same time, obviously, it seems that some kind of non-linear mapping is taking place (which isn't working out as well as probably intended.)
(Actually, based on the extremes in these frames, it's probably more accurate to say that the "average" metering is doing non-linear mapping while the "center" meter is probably more linear. Perhaps if the "center" weighted AE had a mapping similar to "average", center would look better?)
I'm not going to upload the raw .mov files for these at this point.
@jokiin, I can make them available if you want, but this seems to be a fairly easily reproducible scenario.
@Pier28 , considering the amount of traffic I'm generating in this thread, do you regret selling me this dashcam yet?
![Wink ;) ;)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f609.png)
