Yesterday,
@jackkk, a new member asked me,
in another thread, "Did you ever solve your exposure problems with the 2 SG9665GC-V2 that you have? I replied that,
"The firmware got some major and very welcomed exposure fix-its but the answer is basically NO, the problems have not been resolved. I have been unable to find a suitable setting that works properly. Depending on the conditions one is driving through at any given time things looks fine one moment, become excessively dark the next and then suddenly you'll have the highlights blow out quite badly. I've been continuing my testing and plan to post results shortly in the appropriate thread."
Here is the post I promised above:
The recent firmware revisions and attempts to resolve the
High Contrast/Dynamic Range flaws inherent in the SG9665GC have come a long way towards finally addressing the AE issues I first brought to @jokiin's attention some 16 months ago. Unfortunately, this camera and its firmware ares still highly problematic.
I have spent the last few weeks attempting to find a suitable set of menu settings that works reasonably well in most lighting situations and it is basically impossible. I have tried every possible combination of WDR-On/ WDR-Off, Center Cut, Low Cut, Full Frame and EV adjustments, etc.. I've also tried aiming the camera up or down to see if more sky and less of the dark blue hood of my vehicle in the FOV might make a difference but it has only minor effect.
The best results I've been able to achieve have been with either Full Cut or Center Cut - WDR-On - EV +/- 0. This is Beta 22.
Generally speaking, the new Beta 22 version of the firmware has a very dark bias, apparently in an attempt to dial back the camera's tendency to blow out the highlights and upper tonal range. This dark bias is evident in almost every example of sample footage I have seen posted by a wide range of members elsewhere on this site.
The problem I've been encountering is basically this:
Every time I think I have found a suitable exposure setting for this camera, everything falls apart as soon as the lighting changes. Living as I do in an environment with lots of trees and steep hillsides this is a real problem because the light is constantly changing every few minutes or seconds during a typical drive.
A dark bias in dash cam footage wouldn't in itself be a bad thing. We are not shooting feature length movies here. The problem here is that when one goes from a well balanced, well exposed scenario into a less well balanced one that is darker, the camera overcompensates and renders footage that is dramatically too dark, often to the point of being useless for good documentation. At the same time, in certain settings, the High Contrast/Dynamic Range upper range blowouts still manifest quite badly, although happily that particular issues has been much improved in the recent firmware updates.
Here are some screen shots from two days ago. The camera is set to Full Frame, WDR-On - EV -/+ 0.
The shots were all taken on a bright sunny afternoon during the course of about twenty four minutes of driving.
Here I am driving in and out of the tree canopy and so the blown out upper range you are seeing below occurs during the footage every few moments for much of this part of the drive.
Unlike driving though an occasional tunnel or under a bridge, driving under forested tree canopies and along steep hillsides makes the blow-outs a more serious, constant problem rather than just an occasional annoyance.
Anyway, here about one minute later everything is looking pretty good, although perhaps a little on the dark end of a typically well exposed image.
Here, another minute later things are still looking pretty good.
Here it is now about 15 minutes since the above image and everything still looks good, although the sky is rather blown out. (personally, if the camera records the road in front of me properly I don't particularly care if the sky is not exposed correctly)
Two minutes later. Absurdly dark unusable footage.
Here about 4 minutes or so later I encounter some blown-out highlights which often last long enough and can be severe enough to obscure the details of an entire oncoming vehicle.
![blowout2.jpg blowout2.jpg](https://dashcamtalk.com/forum/data/attachments/24/24827-3946e17b467c4c805c4134001e512e2b.jpg?hash=OUbhe0Z8TI)
Then, only 19 seconds after the above image using the same camera settings I started out with on this journey the video is so dark that it is essentially unusable too.
Then, only 4 seconds later the image returns to a reasonable exposure. Yeah, the sky and highlights are all blown out but the camera did a good job of capturing the roadway in front of me and that is what we want to see.
Obviously, the exposure problems inherent in the SG9665GC are still a long way from being resolved, especially for anyone who regularly has to drive under variable lighting and contrast scenarios. And unless these issues can indeed be fixed, the SG9665GC is also not a wise choice if you happen to drive a dark colored vehicle.
