Here one of the video properties taken from Media Player Classic:
General
Complete name : H:\DCIM\100MEDIA\05050719_0579.MP4
Format : MPEG-4
Format profile : JVT
Codec ID : avc1 (avc1/isom)
File size : 100 MiB
Duration : 1mn 3s
Overall bit rate mode : Variable
Overall bit rate : 13.3 Mbps
Encoded date : UTC 2016-05-05 07:19:26
Tagged date : UTC 2016-05-05 07:19:26
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1mn 3s
Bit rate mode : Variable
Bit rate : 11.0 Mbps
Maximum bit rate : 12.0 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.177
Stream size : 82.7 MiB (83%)
Title : Ambarella AVC
Language : English
Color range : Full
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 1mn 3s
Bit rate mode : Constant
Bit rate : 64.0 Kbps
Nominal bit rate : 128 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 KHz
Frame rate : 46.875 fps (1024 spf)
Compression mode : Lossy
Stream size : 493 KiB (0%)
Title : Ambarella AAC
Language : English
Text
Format : Timed Text
Codec ID : text
Duration : 1mn 3s
Bit rate : 7 592 bps
Stream size : 58.4 KiB (0%)
Title : Ambarella EXT
Language : English
Forced : No
