hmhm, you meant £15? at JOOVUU?GT680W in your hand support GPS module,which is 150GBP VAT price.
Yep,that is.That's expensive indeed ,the cost we get from supplier is nearly 40% more expensive than the market's average GPS module price.hmhm, you meant £15? at JOOVUU?
Thanks!
I'll pass mate, thanks for reply none the less!Yep,that is.That's expensive indeed ,the cost we get from supplier is nearly 40% more expensive than the market's average GPS module price.
So if you need,we could send you sperate paypal invoice.
Dunno, but if in parking mode (without GPS), it would mean need to flick through the buttons... kinda thought, with motion detection for that to be AUTOMATIC... then thought need GPS module... but IF with GPS, but not automatic switch over- TOO much Hassle! (lazy sod)!I thought that parking mode just put the camera into motion activation mode or similar?
I haven't plugged a GPS module into my GT680W, but I would've thought it uses the GPS like my G90 for logging purposes only.
Dunno, but if in parking mode (without GPS), it would mean need to flick through the buttons... kinda thought, with motion detection for that to be AUTOMATIC... then thought need GPS module... but IF with GPS, but not automatic switch over- TOO much Hassle! (lazy sod)!also, I don't want GPS for driving mode, in case of me accidentally speeding would become issue of any sort
So what is the point/ can anyone explain motion detection with or without GPS?I can't really comment on the automatic implementation of parking mode, but being automatic sounds a little exotic to me.
Perhaps someone in the know from owning a GT680W with GPS could comment?
I'm using a firmware in my G90 that records the GPS data, but it doesn't display the speed or GPS location on the video footage.
Again, I don't know how the GT680W uses the GPS data but having the data "invisibly" recorded into the video footage is very useful if you need to prove your innocence if it's claimed you've been speeding etc.
Okay... just been out and fiddling with my camera.
Parking mode puts the camera into a very low frame rate setting so your camera could in theory record video for months.
It's not automatic or linked to your GPS.
Very useful if your going to be leaving you car for a long period of time or want to covertly monitor your home etc.
P.S. Motion detection just monitors for any movement.. if movement is detected then the camera automatically goes into recording mode for the duration of the detected movement.
Gotcha!- awesome!I ve tested setting the parking guard at 5 FPS and using that setting to drive around and record footage at...
The results are..
on playback it plays at 6 times the speed ( plays at 30 fps ) which is handy to go through footage quickly and if you use k-lite codec pack to playback you can slow it down to actual speed - This results in slightly jerky footage as its playing at 5 fps, but you do get all the usual ability to read number plates and pause 1 frame at a time and all in full 1080 resolution.
Cant see any disadvantage evidence wise and a 4 g card does 3 1/2 hours or 32g x 24 hours.
only sacrifice is you wont get the fluid footage that serves no purpose but for looking good on you tube and the advantages far outweigh !!!
(I was so impressed I had a go at loading v3.0 into my g1wh via a bin name change but it wouldn't have it ! )
Gotcha!Parking Mode and Motion Detection are two separate functions/modes and I don't believe they can be combined.
Using a low frame rate and motion detection wouldn't be a good move as you could easily miss a very short event or only end up with a few unusable frames.
You want full motion HD video when an something happens![]()
