Right that’s it
![Mad :mad: :mad:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f621.png)
I'm never knowingly buying such cheap crap like the GW860W again!!!
After only an hour of testing my new camera, it did exactly the same as the last one and overheated and went berserk!
Here's the cause of the problem... apart from the GW860W being absolute garbage (especially when you open it up and see how poorly it’s constructed inside).
I’m using the charger that was supplied with my Dome G90 as I didn’t want to use the one supplied with the GT680W because the voltage converter and ferrite core (which are in a really stupid place on the cable) wouldn’t allow me to route the cable round the windscreen and through the dashboard etc to get to the lighter socket.
The standard specification for USB output voltage is 5V +/-5%
However the G90 charger gives out 5V +9% e.g. 5.45 volts.
This equates to only a measly 0.20 volts above the recommended specification, but is enough to wreck your G860W!
On close inspection of the G860W’s PCB, there appears to be absolutely no voltage regulation and/or overvoltage protection on the power input to the camera.
So if you pump in slightly too many volts for a short duration, it will cause the unit to subtly overheat several key components and cause a snowball effect.
Once the camera has initially overheated, the camera will excessively overheat on subsequent uses (even if you power it below 5 volts).
I’m not prepared to keep running it too see how hot it will eventually get (as lithium ion or polymer batteries are not funny when they overheat), but let’s just say the battery and several other key components were almost too hot to touch!
...and to add insult to injury it will eventually overheat and fry your Micro SD card!
So if you’re thinking of using an alternative charger or a battery pack to power your GW860W, be very careful you don’t inadvertently kill your camera or worse.
Right... that's my rant over... I'm off to put my original 4 year old trustworthy dashcam back in the car (which has been happily running of the G90 charger for 6 months)
![Roll eyes :rolleyes: :rolleyes:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f644.png)
