SJCam M10+ Firmware update V1.5 and later
- New Procedure -
The SJCAM M10+ 2K Gyro it's receiving a newer firmware that adds bug fixes and improvements. This new update will also need a one time additional step to prepare the camera for future updates.
Please pay attention to the following official update procedure:
SJCAM M10+ 2K Gyro
Upgrading Firmware to v1.5 Tutorial
Updating firmware Version 1.5 for the SJCAM M10+ plus has several new steps. You will need to install a Loader file first (LD96660A.bin) and then the Firmware (SJCAMM10.bin).
Important: The firmware and process is only for units with M10+ v1.5 firmware and below. Firmware versions above 1.6 will not require the first step which is installing the Loader software.
Warning: Once the M10+ firmware has been updated to Version 1.5 or 1.6, you cannot flash the M10+ to lower firmware versions. This firmware is only for units with Versions v1.5 and below. If you revert back to a firmware version lower than v1.5 (like v1.3, v1.4), you will brick your camera and it will no longer be functional (black screen).
Installing Loader Software:
a)Make sure to format the microSD card.
b)Copy the loader “LD96660A.bin” into the root of your MicroSD card.
c)Insert microSD card into the M10+ unit and power the camera on. Note: makes sure the camera is off when inserting the card. Once the camera is powered on, turn the M10+ off and remove the card.
d)Delete the loader LD96660A.bin from the MicroSD card. Next, copy v1.5 firmware file “SJCAMM10.bin” into the root of the microSD. Note: there is no need to format the card again
e)Re-insert the MicroSD into the powered off M10+ and power the unit on. It may take 10-15 seconds for the firmware to install. The blue and yellow light will blink until the firmware is installed and then the unit will power on. Check the firmware version to confirm version has successfully been updated then delete the firmware file SJCAMM10.bin from card otherwise the firmware will re-install upon re-powering the unit on.
1.5 Official Changelog
1) Fixes the Duplicate License Plate Number watermark issue under "LicenseNoSet" menu option. Also fixes the license mark not being removed when option is deselected.
2) Fixes issue when after the unit has been powered off, then powered back on again, the Gyro settings need to be reset. Adds a Gyro Sensor Quick Key - when using M10+ to record or take pictures, gently press the WiFi button to switch the Gyro off/on. Press the button down longer for Zoom.
3) Improves automatic white balance (AWB)
4) Fixes left side of the screen has a line issue.
5) Enhances Wifi signal strength and improves Wifi signal stability.
Warning: Once the M10+ firmware has been updated to Version 1.5, Do not flash the M10+ to lower firmware versions. This firmware is only for units with Versions v1.5 and lower.
If you revert back to a firmware version lower than v1.5 (like v1.3, v1.4) you will brick your unit and camera will have a black screen
How to update short video guide
