I've been testing the gyro stabilisation:
In these three videos the M10+ is mounted on a monopod which makes the job of the gyro a bit easier due to the increase in inertia. The monopod also keeps the horizon horizontal. When just hand held, the results are similar but it is easier to push it beyond it's limits and cause jumps in the movement.
Note, I have given all these videos a small increase in gamma and changed the colour balance slightly since the video from the camera is a little blue for my taste and the WDR appears to do nothing. I will post some raw unmodified video when I've done more testing, the screen shots at the end of the post are straight from the raw video.
First video: I gave it a simple job, just moving around gently, it produces smooth movement with a bit of inertia. The result is considerably better than without the gyro. In fact without the gyro I would have put the monopod on the ground to get a stable shot of each view and cut out the movement between views.
Second video: This is with the camera on full zoom, x4. The movement now has a little shakiness but it is still perfectly useable video. The x4 does produce a bit of noise at times and the image is not as sharp as expected.
I think the sharpness issue is just that the lens is poorly focused, it seems to be in good focus from 0.3m to 3m instead of 0.8m to infinity. I will take it apart and try to refocus it after I've done a bit more testing.
There is also a glitch just after the start where 1 frame of the video has no colour! Not impressed by that, maybe I need a faster memory card?
Third video: The 1st half is quick walking, 2nd half is running, no zoom until the very end.
The gyro does an excellent job, you couldn't do that with any computer software I've ever tried.
The lens flare is not so good, it is understandable walking directly into the sun with the sun low in the sky but the Git1 would just have a couple of small circles in that situation, this lens is not the best. Going back up the steps, there shouldn't be any lens flare, the problem is that the lens sticks out beyond the lens barrel so the sun can still get to it even though the camera is at 90 degrees to the sun and at that angle the sunlight bounces around off all the internal surfaces. Concrete walls can also get the lens if you happen to brush the camera against one while walking! I expect a lens barrel to protect the lens, this one fails.
There are a couple more glitches in this with dark flashes.
I like to be able to use a bit of zoom even if it doesn't give the best quality, that is one of the reasons for having a higher resolution sensor, I don't want it to put a beep on the soundtrack every time you use it though! And it doesn't have to zoom so fast that you can't stop it before you hit maximum!
There is quite a lot on this camera that needs tidying up and improving but the gyro stabilisation is very useful and works well, the picture quality is also reasonable and it is quite a nice camera to use, I like the shape. The lens needs better focus and those glitches need sorting but maybe those issues are just on my camera?
This is just 1 frame of the geese video, all the other frames are normal:
