Got it! I'll give it a go. Thanks.you got PM
That is freaky! I too would not have thought it was possible. Can you actually operate the camera with both devices at the same time? For example, can you start recording with one device then stop with the other? If you bring up a menu on one device does it also show up on the other? Now the next test: What happens if you get a call on the phone? Can you answer it without losing the phone's WiFi connection? What happens to the tablet while you're on the phone?you can connect more things to the Sj7 at one time, here to prove both my tablet and phone is connected to the camera.
Dazzne P2 Plus and it's app.
http://www.dazzne.com/article/detail/id/68got a link to their app?
Which firmware are you currently on?I'm sure they connected because when I originally got the camera it was set to the default date, 2016 something. When I connected with the phone the date was updated to current even though the app didn't work.
Once I got the battery door open I removed the battery, waited a few minutes and tried the app again. I'm not sure if that potentially makes any difference but in fact it didn't.
The iOS app has worked all along.
I really wonder if it could be the 1.05 version firmware.
Sorry I wasn't clear. My Android phone, using the SJCam app, connects to the SJ7, I get the app start screen, but then nothing happens except the little wheel at the bottom of the screen keeps turning. I'm speculating that it might be because I only have firmware version 1.06. As far as I'm aware that is not the latest version.We just tested and it turns out that you can connect two devices but only one can control the unit and when you press something, the wifi on the the 2nd device drops.
We tried the Dazzne app in the link and we could not connect to the SJ7.
Can you confirm the firmware /app versions you are using?
I paid for my SJ7 but also would like to help test the new firmware. I've PM'd SJCAM as well and haven't gotten any response to get in the private tester forum so I am still stuck on 1.06 FW. If anyone has the link for the new firmware and would like to share please send me a PM. Thanks!
Sjcam official are not on here that often, or that is mostly when it is night / late here in Denmark it seem.
Which APP + firmware version are you on?Yes, swiping down on the screen and pressing the WiFi icon worked, and yes, if it was on when you turned off the camera it turns on automatically when you turn it on again. Thank you once again kamkar1.
EDIT: Now if I could only get the Android app to work. iOS app works fine.
I just installed firmware version 1.09A. The app is version 5.1.2. I just checked the Android app using my Samsung Galaxy S4 phone and unfortunately I'm getting the same result. The phone and camera connect and I get the app start screen but nothing more. The little wheel at the bottom of the app screen turns but nothing happens.Which APP + firmware version are you on?
SJcam S7 Star With External Microphone | SJ7 | 15 | ||
H | SJCAM SJ7 STARS + GIMBAL SMOOTH Q | SJ7 | 25 | |
SJCAM SJ7 Star Review | Here's Everything You Need To Know | SJ7 | 7 | ||
H | TEST TIMELAPSE SJCAM SJ7 STAR | SJ7 | 2 | |
T | Sjcam sj7 star timelapse | SJ7 | 12 |
