Made this little head 2 head earlier today.
I think i have the focus on the SJ7 dialed in a bit too close as opposed to the a bit to far out it was when it arrived.
SJ7 also seem a bit over the top on the colors, except the grey sky that the SJ6 might be a little closer to the actual color, but the grass was not that lush green.
both 1080/60
Gyro on and on the Sj6 set to low ( dont seem to work on SJ7 yet )
SJ6 was only med bitrate and SJ7 was high
both WDR on
I get a 404 error when I try to open the links. Can you try something else? Should I try something else?Original video 1080-120 fps. Visible "grain" on a dark background. https://cloud.mail.ru/public/2HYi/nZn6cDafT and https://cloud.mail.ru/public/AvbX/6XVMXc7Wh
https://cloud.mail.ru/public/AvbX/6XVMXc7WhI get a 404 error when I try to open the links. Can you try something else? Should I try something else?
Thanks. Link worked, having a look now . . .
Please drop a source file on file sharing filmed in the format 180-120 fpsYeah it is not as smooth as you would expect, off course at 1:1 you dont see it.
I am looking forward to get some sunshine so i can get some optimal footage, that i will then go thru and look over frame by frame to see what go on.
I assume its frames that get dropped, but i will have to do a count to verify that.
