Street Storm CVR-A7810-G, FoxOffer SZDome G90 / G98 and A7 / OV4689 clones
To be honest I've not really seen any firmwares from the DODMT D99 - the one I've seen was running a Street Storm firmware anyway and the D99 ran all the Street Storm firmwares I tried.
The guys over at autowrzuta.pl have a UK speed camera database and a full EU one over here:
http://autowrzuta.pl/viewtopic.php?f=28&t=3120&sid=3cf9bb21b454451da28585f30abe23fc&start=275
I'm assuming it doesn't cover Turkey but the guys in there should be able to say how it was created and then the same could be done with a Turkish data file to translate to the right format 🙂
A very nice little camera though - @JooVuu can help with supply of these.
Hi again : )
Today I received my DODMT D99. It smaller than my expectation.
As first thing, I checked firmware number! "DOB47FSHZDGE.140723.V1" is it familiar to you? Because Street Storms begin with SS..
And one more question? is street storm firmware has also English language or only Russian?
Do you know any method back-up current software in case of anything?
I've got to admit that is definitely an older firmware version - I have the same version here with the SS firmware which is up to version 150427 on their website:
http://streetstorm.ru/support/cvrupdate.php
You can back up the firmware usually with an autoexec.ash file - usually with the following contents:
firmfl gen 6 bst bld hal pri rom dsp d:\backup.bin
Create a file in Notepad++ called autoexec.ash and ensure the line breaks are set to Unix format (Edit - EOL Conversion - UNIX...) and save that in the top level of your memory card.
Now turn on the camera, stop it recording but leave it running for a minute and then power it off and pop the card back into your PC and fingers crossed you'll have a file - to test it try and load it into AFTTool and if it looks ok then you've got a good dump.
I had this camera fitted last week and I'm still impressed with the footage it records.
Great, thanks, I will try to do it.
Is there anyway to back-up current firmware in case any situation.
really impressed by the pro version ...
I have been trying to find out how to load the UK speed camera files in but drawn a blank despite having the files downloaded..
has anyone done this successfully ?
and can you tell me how to...please🙂
