RavenManiac
- Jun 18, 2015
- Williamsburg, Virginia
- Viofo A129 Duo, mini 0806 (RIP)
[UPDATE]
So here's the latest. I placed a Drok USB Tester between the micro USB power cable and the mini 0806 and drove the car for a few hours. Here's what I discovered. Under load, the Drok USB Tester reported 4.8 volts and .42-.60 amps. Not sure why the big variation in amps.
Now here's where it gets weird. Occasionally, but not always, when the car comes to a stop and idles the voltage will drop to 3.65 volts and as low as .10 amps. What the heck? Is this a USB charger issue or is there something bigger going on, like perhaps a bad alternator or battery? I haven't noticed any other devices that have been affected. Only the mini 0806.
won't be a car problem (battery or alternator), the camera will only draw what it needs so the variation in amps is nothing to worry about, with the voltage sag though I would think it's more likely the camera is the culprit (assuming you've ruled out the obvious already, swapping outlets, cables etc) the power supply design on this camera is not good and is the cause of most of its issues
Sounds like this is more of a power supply issue. Wouldn't the volts be determined by the device that's producing the power, which in this case would be the USB Charger?
Okay, so here's the latest. The mini 0806 appears to be charging fine when connected to my MacBook Pro. The battery will last about 10 minutes, which is normal. That means I either have a problem with the GPS mount or the hardwired power supply. I guess the next step is to plug the mini USB cable directly into the camera to bypass the GPS mount.
I can't believe after all the posts, tips, tricks and hints, you're still using the base's USB ports to power your cameras. That should be step one in any diagnostic/troubleshooting process. DO NOT power your camera from the mount. The retractable pins in the mount are inconsistent at providing good conductivity between the camera and the base. It may work fine for a while, but between vibration, oxidation/corrosion (not necessarily visible), weakening springs, sloppiness of the mount interface, you will eventually have unstable voltage and current getting to the the camera - which will cause all sorts of issues, many of which will mimic a failed battery.
I never bothered to check my situation out as you have. My mechanic checked my car battery and told me that it was fine and putting out 12v. But I did not check out the voltage coming out of my USB ports. I am not the do it yourself type to strip out a cable's positive and negative. As I am a coward , I have gone the easy route - I went to Amazon and purchased a PowerJive USB Voltage/Amps Power Meter Tester for $9.99 (https://www.amazon.com/gp/B013FANC9W). It will come on Sat and I'll check out my USB voltage.
Yes, it probably is. I'm going to try a few more things and then I'm pretty much done with this dash cam.This is becoming your profession.
Perhaps time to give up on the Mini's?
S | Mini 0806 Battery and Firmware | Mini 0806 | 0 | |
B | mini 806 2.7 volt 5.0f capacitor to 402030 li-po battery | Mini 0806 | 5 | |
W | New battery ordered | Mini 0806 | 7 | |
Quick and dirty way to test for battery issues | Mini 0806 | 3 | ||
External Battery/Supercapacitor | Mini 0806 | 3 |
