Berz888
Ah. I'm in Richmond.I definitely prefer hardwire over everything. It says you are in Canada. Where are you located? I am Greater Vancouver area
I was in RIchmond earlier today. I could have borrowed you a cable to see if it corrected the issue.Ah. I'm in Richmond.
Ohhhh, that would have been amazing. DM me next time or if there's a way we can connect that would be super.I was in RIchmond earlier today. I could have borrowed you a cable to see if it corrected the issue.
Great newsI ended up picking up the IROAD OBD connector. It's now working as expected.
Hi Berz888, I am about to install U3000 in my car and I want to use IROAD OBD cable instead of Thinkware becasue the IROAD cable has simply 2 pins. Can you please share your experience so far with IROAD OBD cable ?I ended up picking up the IROAD OBD connector. It's now working as expected.
What make model and year of vehicle?Hi Berz888, I am about to install U3000 in my car and I want to use IROAD OBD cable instead of Thinkware becasue the IROAD cable has simply 2 pins. Can you please share your experience so far with IROAD OBD cable ?
VW Touareg 2023.What make model and year of vehicle?
I have been hearing that if it is a new body style vehicle it is not supported on some 2023 models.VW Touareg 2023.
can you please elaborate more about new body style vehicle? VW Touareg 2023 is same as 2019.I have been hearing that if it is a new body style vehicle it is not supported on some 2023 models.
Thanks.new mercedes glc they changed the computer, fusebox and etc. If everything is the same on VW Touareg you will probably be fine. But most likely 2024 will be new generation. WHich means it will not be supported on 2024
The IRoad obd has been working flawlessly with the U3000 since I've installed it. Will 100% recommend.Hi Berz888, I am about to install U3000 in my car and I want to use IROAD OBD cable instead of Thinkware becasue the IROAD cable has simply 2 pins. Can you please share your experience so far with IROAD OBD cable ?
Thanks Berz888. May I know how many minutes the camera is switching to the parking mode?The IRoad obd has been working flawlessly with the U3000 since I've installed it. Will 100% recommend.
Thanks, I have tested again and it seems working fine. But I noticed the driving mode will be activated after the car movement and not with powering the car on. Do you the same behavior?It varies as it depends on the battery voltage to switch for the IROAD. In my experience, it can be from 2-5 minutes.
The U3000 has such low battery usage during parking mode that even after 5 minutes it will be on for many hours after.
For parking mode activating, that always happened to me with using the original thinkware hardwiring. Only when I switched to the IROAD thar issue went away.
Might be a faulty IROAD cable ir compatibility issue? Can you exchange it?
Drive mode for me activates when I start the car.Thanks, I have tested again and it seems working fine. But I noticed the driving mode will be activated after the car movement and not with powering the car on. Do you the same behavior?
For me, the driving mode activate when car is one and moving.Drive mode for me activates when I start the car.
Iroad obd2 cable logicDrive mode for me activates when I start the car.
