Julian23
- Nov 16, 2016
- Germany
- Several brands :)
I got my hands on the new LT01 module from Vantrue.
This will be a quick introduction to it.
Here are some pictures of it.
What is the LT01?
The LT01 LTE module allows users to connect certain Vantrue dashcams for remote functions.
To power the LT01, the plug that would normally go into the camera, is plugged into the LT01, and the cable from it goes into the dashcam.
With this, the LT01 and dashcam both shutdown when the voltage is too low and activate once the ignition is back on.
According to the Vantrue Connected App, the currently supported devices are:
What can it do?
As seen above, it allows users to:
2,4Ghz and 5Ghz are available as a setting.
The name and password of the hotspot can be changed.
The most important feature however is the remote access to the dashcam.
The app allows users to:
(Purposely no image because the E360 is not yet installed in my car)
The latency is about 3-4 seconds. The audio and video quality are good.
Activation:
To activate the LT01 you require an active SIM card and a Vantrue dashcam from the supported devices.
The LT01 requires the micro SIM format. The tool to eject the SIM card tray is included. I disabled my SIM PIN for use in the LT01.
After plugging everything in and turning it on, you need to select your model and follow the steps on the screen.
If everything is connected right, this should be done within a few minutes. The app makes this very easy.
Once connected you will be able to access all the functions I listed.
The LT01 manual is not yet officially listed on the Vantrue website. A link can be found with the QR code in the box or with a simple search on the internet. š
I will provide more information once the E360 is installed in my car together with the LT01.
What is the LT01?
- E360
- E1 Pro
- N2X
- N4 Pro S (new model to be released?)
- N5 S (new model to be released?)
- S1 Pro
What can it do?
- Create an electronic fence:
- Access messages sent in case of events
- Locate the vehicle on the map and navigate to it
- see data usage statistics
- change LT01 settings
- Access the local and cloud folder
- Start and Stop the recording
- LTE Screen recording (records what the dashcam is seeing and allows users to save it)
- Switch camera view
- Intercom
- Disable/Enable Audio recording on the camera
- Playback recorded videos that are saved on the SD card
- Change any camera settings (resolution, parking mode, etc.)
Activation:
