vvs49
- Jan 8, 2015
- Ukraine
Yes, there is blur in this firmware.OK but very slight blur.
VIOFO has a lot to work on !!
Because the current firmware version of A119 V3 adds HDR. That causes some changes in image quality.
There is a software WDR and it worksThere was never WDR on V3 just because the IMX335 doesn't support WDR.
It was I who replaced the name of the WDR with the HDR, then there were no firmware from the HDR !!
November 2, 2019
Right!So only name was changed is that right? We should not expect big differences between old WDR and current HDR yes? There is no reason to get back to old versions am I right?
No, but why the old firmware?Are Viofo wrong?
In the last menu, turn off HDR and the freeze frame will be as before, but at night the car numbers will not be read.
Better yet, install the firmware from the HDR auto, and select from the menu when on / off. HDR
Without night use, firmware 1.03 is very good!!I knew I would be passing that same spot a few days later so I reinstalled 1.03 and captured the item with almost no motion blur.
Thank you for your answer."a signal resounds with an image with two big points red and green on the dashcam screen"
Check this :
Image is very bad!!I found the image quite good !
Yes, you are right...Image is very bad!!
You have a problem with your windshield!!
Such beams should not be!!!
And HDR is not working, 18.28 and HDR is off!!
