if H265 is not enabled, there will not be 2160P resolution, only 2560x1600 30fps, 2560x1440P 30fps ........H265 options - it just shows the same resolutions as it did before (3840x2160P 24fps, 2560x1600 30fps, 2560x1440P 30fps, 2304x1296P 30fps etc.)
which is also interpolated, something to keep in mindif H265 is not enabled, there will not be 2160P resolution
This resolution = H 2653840x2160P 24fps
Does https://dashcamviewer.com/ work with A119 V3?
It's just that you probably confuse some of the concepts, in addition, the instruction may not be in time for improvements and changes in the firmware.So I've received the A119 V3 Thursday and the HK3 hardwire kit yesterday. Installed into my vehicle and now I cant seem to understand how the parking modes actually work. I've tried triggering the Parking mode G-sensor "sensitivity high" by tapping it but haven't been able to get it to activate. I've tried the lower fps modes but when I tried that at 5 fps the video was recorded at normal 30 fps but playback was quite fast. This is confusing me, when I lower the fps on my home security system I don't notice this speed up on playback only less frames for the cpu to process and data across the network & storage. I've looked all over and haven't been able to find a video that goes into much detail on Parking modes. So my question is has anyone thoroughly tested each of the Parking modes that could explain each of them, pro's and cons of each that a lay person would understand?
Timelapse is not a video recording at a speed of 5 frames per second, it is a frame-by-frame shooting that "sticks together" into a video clip, so in the file properties you see 30 fps, the video should turn out to be "accelerated", in this
case 6 times. This has nothing to do with CCTV/security systems.
Check the Low Bitrate Recording mode, this is one of the most optimal now, along with the recording mode using the G-sensor with buffering. One minute of recording takes up just 30 MB. This is a stable record of everything that happens.
I've still been working with parking modes and noticed tonight that when connected with HK3 hard wire kit in Parking mode "Auto event detection" if I purposefully cause a triggered event with the G sensor by tapping the A119 V3 it flashes the yellow caution icon, beeps 3 times and starts recording a 45 second video. However it did not place the files in the RO folder as I expected, it placed them in the "Movie" folder as Date_TimeP.mp4 @ 8Mbps as if a normal parking mode file. Has anyone else noticed this or is this expected behavior or known bug??
It was my understanding anytime an event triggered the G-sensor it would lock the file and place it into the RO directory and that's not happening on mine. I also notice after it displays the Caution across the entire screen it places the yellow Caution Icon at the top of the LCD header while it writes that file but once done writing it's gone. IMO it would be greatly beneficial that the Caution Icon stay on screen in the header until the user clears the event, especially if it doesn't lock the files in the RO folder.
Not me, I just use mine for recording whilst driving and therefore all sensors turned off or set to minimum.
Car garaged so need for parking mode.
This is how the g-sensor originally locked parking mode files on the A129, but it was changed in a firmware update. I'm sure once Viofo is aware of this they will change it in a future update.
Correct, A129 g-sensor triggered files did not go into the RO folder until they changed it in an update.So your saying the A129 did not lock files in the RO directory when in Auto detect parking mode with G-sensor trigger? I'm still waiting on Viofo to get back with me, my ticket said they usually get back within 24 hrs and we're at about 28 hrs now so hopefully I'll hear from them by the end of the day. Would still be nice if someone that had the A119 V3 could confirm if there's acts the same as mine, just to make certain I don't have a defective unit.
I will try to test a A119V3 unit I have to see where the g-sensor files go, but I doubt you have a defective unit.
