I use MOD v1.5 from FalsificatorIs this an increased bitrate from stock and if so does it affect running temps ?
Don't forget to manually default the cameras settings after updating, then press and hold the reset button for about 5 seconds. Always good to do this.Installed.
The mirror image is just that.
Defaulted the settings, but didn't do the reset button. I'll do that.Don't forget to manually default the cameras settings after updating, then press and hold the reset button for about 5 seconds. Always good to do this.
Yes, I believe HDR is replacing WDR.No more WDR setting? (I thought I remember it had WDR, that I had set to off).
HDR taking its place?
I have not seen this feature yet, but I would assume it applies only when using the HK3 kit.Is the Parking Mode Timer, ie, 0 or 90 seconds delay, only for the HK3 (ACC trigger) setup, or should it go into parking mode with it resting on the table with power fed to it?
It will work without the HK3, however once asleep it won't wake up again, with the HK3 it will wake up again on ignition which is far more useful. (Based on my test on another Viofo camera, not A119.)Is the Parking Mode Timer, ie, 0 or 90 seconds delay, only for the HK3 (ACC trigger) setup, or should it go into parking mode with it resting on the table with power fed to it?
