Falsificator
- Mar 15, 2014
- Kaliningrad, Russia
- Russian Federation
- Ambarella, Novatek
At the moment I'm experimenting with values and parameters in extreme positions.Is there a download link here ?
The parameters of contrast, gamma and black level are more or less worked out. Now the task is to achieve maximum detail.I'm impressed with the before and after, the clarity, especially the washed out v clear clouds in daytime.
There are bugs. Work continues...
These are the most important, double under the HDRWhat bugs are still present? Maybe I can help out?
We are still waiting Novatek to fix this, if this fixed, the new firmware will be closed to release.These are the most important, double under the HDR
What is the issue with the images? Do you mean the motion blur of the license plates?These are the most important, double under the HDR
Double objectsWhat is the issue with the images? Do you mean the motion blur of the license plates?
there is no blur, there is a bifurcation!!I strongly assume that this is motion blur.
There are two separate exposures visible in each frame, but no motion blur.What do you mean with "bifurcation" - I don't know this term in this context, only from fingerprint analysis
A119S doesn't have HDR, different technologyHard but not impossible. A very good exemple is A119s where HDR ( WDR ) works flawlessly.
A119 V3 use also WDR and not HDR. Both of them works on the dark and bright details to be clear under the high-contrasted light condition. WDR is hardware and HDR software. For this reason ( 119V3 use WDR ) we can do nothing, only Novatek can do.
