I'll build it for you and others to demonstrate it works in any combination, you then test for function and stability.
updated:
Your Selection of A119S v2.61 > 1080@60fps = 25Mbps + 1080@30fps = 25Mbps + Sharp32 has been created.
Download it from my online Drive folder (( Custom MODs ))
A119S MODs https://drive.google.com/open?id=12fZcd7vuglroUOsL0lHClORbclbXQqLv
Seeking A119S owners to flash update FWA119S_v2.61+25Mbps+Sharp32+Edge168+DICE.bin
All Bit Rates supported 27.5 - 15Mbps, started with 25Mbps to attract owners fearing meltdown from 27Mbps.Only for 25Mbps version? The 27Mbps version doesn't have these updates?
I will try it tomorrow. Thank you!All Bit Rates supported 27.5 - 15Mbps, started with 25Mbps to attract owners fearing meltdown from 27Mbps.
Try FWA119S_v2.61+25Mbps+Sharp32+Edge168+DICE.bin for a few days, when more feedback supports this combination I'll create full range of Bit Rates.
I have more than 4000 miles with the 27.5 Mbps version with no problems. The parking mode doesn't work properly but i don't think that is a heat issue. I just don't use it anymore and it is all good.the rise from 24mbps to 27mbps is just 12%. the camera should be able to handle it without overheating, I think.
agreed, 27Mbps will work, was considering 24Mbps to persuade fence-sitters to actually try this possibly best video image quality firmware modification released so far.the rise from 24mbps to 27mbps is just 12%. the camera should be able to handle it without overheating, I think.
Just uploaded the Edge Detection MODs for A119S.
Video comparisons indicate improved object definition after combining Sharp32+Edge168, Download MOD from (( Custom MODs )) folder.
Seeking A119S owners to flash update FWA119S_v2.61+25Mbps+Sharp32+Edge168+DICE.bin (rename the MOD file to FWA119S.bin).
Review footage for enhanced object definition without halo effect from over-sharpening.
More video quality improvements on the way, Thanks for the support.
DOWNLOAD A119S Modified Firmware https://drive.google.com/open?id=12fZcd7vuglroUOsL0lHClORbclbXQqLv
DOWNLOAD A119 Modified Firmware https://drive.google.com/open?id=1d47InQ8qHSkZCgVfxersR1gflsd3hQTN
DOWNLOAD A119PRO Modified Firmware https://drive.google.com/open?id=13l_iCWCDkfbS895arQXlRJZNu64sCtS1
DOWNLOAD A129DUO Modified Firmware https://drive.google.com/open?id=19l3yGyvkrRZMiyRBJVw7oGCFUcNWheYa
Good footage during cloudy day (lower light conditions), looks good with reduced halo but needs more POP!Here are 2 samples, all default settings:
With CPL
https://www.dropbox.com/s/zo04sykhid0raw6/CPL_FWA119S_v2.61+25Mbps+Sharp32+Edge168+DICE.MP4?dl=0
Without CPL:
https://www.dropbox.com/s/tggq5uzav2040x0/NO_CPL_FWA119S_v2.61+25Mbps+Sharp32+Edge168+DICE.MP4?dl=0
Looks like a lot of compression artefact to me do you have the RAW image?
*EDIT* I downloaded the full video rather than watching it in the player and it looks much better now.
Testing higher levels, try this tweaked version FWA119S_v2.61+25Mbps+Sharp37+Edge228+DICE.bin <<<< saved in (( Custom MODs )) folder
Welcome to the DashCamTalk Forum, good to hear from those on the fringe looking in.BCHobyist,
Thanks for doing the work for all the people here.
First time post, but lurked for a while.
I loaded up your FWA119S_v2.61+25Mbps+Sharp32+Edge168+DICE.bin.
Here is a video of the drive home. Over 100* here, almost clear (smoke from the fires)
This is with the CPL. Let me know what you think.
Mod Firmware Video 08-17-18
Thanks for sharing the RAW footage, It helps all of us to determine the best adjustments. The combination of 25Mbps+Sharp32+Edge168 Modifications do produce a very good image, great job testing my FW MODs.
If possible can you load up a slightly tweaked version >> FWA119S_v2.61+25Mbps+Sharp32+Edge188+DICE.bin
My A119S also suffered from exactly what your Lens displays, The center area is slightly out of focus, probably due to high temps in your region. Review previous clips recorded on cooler days to confirm same center focus issue. Correction is possible with a little guidence, simply pry out glue from Lens barrel threads using needle (hold it as shown in my video, mark current position with whiteout or paint on needle, point Lens away from body) then delicatly turn Lens (holding sensor board firmly) counter-clockwise 0.2-0.4mm. Reassemble and done.
How to check focus:I will load up the other firmware tomorrow. I have no footage for a cooler time as it has been well over 100* for the past 30 days.
