acters
I have no words for the type of frankensteining type of work that is being conducted here. Please understand that a single antenna is limited at a physical layer.(It can only do as much as it can) Software can only compensate for this, not improve or modify the physical behavior.Hello Acters.
I started the two wget-instances only ~2sec. apart. Both instances grabbed the same file. But data-amount per stream was ~1/2.
One corresponding file is created in the directory but the file is somehow corrupt (maybe of incorrect parameters?). VLC doesn´t play it, but without any error-message.
Because of this (behaviour) i wanted to give aria2 a go if it somehow might be superior to wget regarding that.
I wish for so much more from these high priced dash cams.Pretty much all the time, or almost all the time i have been into dashcams have a asked for another storage media.
But having that, and a large one, well you might want a few things to come with that.
1: A automated backup routine, so when you backup you only backup footage recorded after your last backup.
2: Means of backup, so this could be to a fast USB thumb drive, or also via the air to your home NAS or cloud service, personally i would prefer a USB thumb drive as really i dont use WIFI or other wireless technologies other than for controlling RC hobby things.
ATM i am mostly inclined to want a M2 drive, 2 TB would be sweet, and actually not cost that much. This if you get a newer gen 4 X 4 drive, would also have read / write speeds to support several 4K cameras in the system, for sure cooling a SOC that would handle that would be the biggest problem.
Bringing me to the remote cameras systems i favor, CUZ then your main unit can be as large as you need to accommodate a proper cooling solution, and really it could even be active cooling.
The only solution I have come up with that is semi-satisfying for this need to have better storage capabilities is to get a SD Card Multiplexer that can switch between two SD Cards. One for the camera and the other has the data offloaded to an external system, like a Raspberry Pi with an SSD attached. This multiplexer is niche and needs to be made by hand. It is such a pain to not have a proper storage medium, I hate SD Cards. For now I simply bought a SD Card for every day of the week, Swapping manually and formatting the SD Cards before I put it in the camera. I read online formatting an SD Card prolongs its lifespan. /shrugs
For the active cooling part, you can just stick a fan on it and hook it up to the cars wiring, or separate battery pack.
I drive an electric vehicle, the 12 V battery is kept charged up when driving or charging the larger Li-Ion battery. which is everyday and EVs don't need lots of power to turn on, so I don't worry with a battery pack.
