Perhaps they heard you and fixed it.That additional line wasn't there when I posted! However, maybe Viofo are still getting the page ready for public viewing....
Is this compatible with a CPL? I see indents on the housing.
The CPL-500 for the telephoto camera will be released soon.Is this compatible with a CPL? I see indents on the housing.
The telephoto camera was Nigel's idea I heard.
No, that was me six years ago and @TonyM presented the first viable DIY prototype with his A139 Pro mod.
Back in the time of Kamkar's thread, there were no 4K dashcams, and telephoto lenses made a lot of sense. Once 4K+1K dashcams became available, at about the time of Dashmellow's thread, fitting a telephoto lens to the second camera of a 4K+1K dashcam did not produce great benefits. If you used a lens with enough magnification to beat the 4K front lens then the field of view was too small. It was not until we got 4K+2K dashcams that a telephoto lens for the second sensor really made sense again, and now with 3 channels so that you can have front + rear + telephoto, it makes a lot of sense, and with good DOL-HDR as well, the RTC300 telephoto is working really well, until the 8K+2K dashcam arrives, at which point the 2K telephoto will not show much advantage over the 8K front again!Nigel has actually been against telephoto cameras for a very long time and has no experience with them,. He claims that 4K camera resolutions allow you to zoom into the image, so you don't need a telephoto
I don't think you want to replace the rear camera with this, the field of view is too narrow to use on its own, you need both.I'm quite interested in this but I don't want to lose my rear camera so I can use this for the front. Do you think it's a good idea to use this as a rear camera instead?
Thank you.I don't think you want to replace the rear camera with this, the field of view is too narrow to use on its own, you need both.
Normally, when you want to view a recording of something distant, it will be at the front.
So this takes the rear camera socket, and you either use the interior camera as the rear camera, or use an independent rear camera such as the Viofo VS1 or A119 Mini 2.
Yes you can not run such a camera alone, it need to be paired with a regular wide angle cameraooo zoomed in that it won't be able to capture anything else.
Hmm, I was not the first to implement a telephoto dashcam, doesn't appear that Dashmellow was either, @kamkar fitted an 8mm telephoto lens to a dashcam back in January 2015, that is 9 and a half years ago, much longer than Dashmellow's 6 years ago!
Here is Kamkar's thread, unfortunately missing it's images after all this time:
Long range plate reading, a little lens experiment.
As a experiment i put a 8 mm megapixel lens on the 0806 to see how far off licence plates are readable. I have no exact specs on the lens other then what is above, got the lens off a 1080p IP camera so i assume its a 3Mpix lens. Here is first some pics so you can see how narrow the FOV is...dashcamtalk.com
TonyM was using a 2K Mobius with telephoto lens for his thread, paired with a separate 4K front camera, so his telephoto works OK, not much different to the RTC300, although it doesn't have Starvis 2 and DOL-HDR so has more motion blur, and he eventually opted for less magnification.
So I think it was Kamkar that started the telephoto dashcam idea, I think it was Tony's thread that really influenced Viofo to produce a telephoto, and it is the introduction of 2K secondary cameras for the telephoto lens and a third channel for the rear, plus Starvis 2 and DOL-HDR that has brought it to production. It wouldn't have happened before the 3ch A229 Pro/Plus arrived.
We also shouldn't forget Mtz, for his work behind the scenes, he has had a significant input to the RTC300.
So, no, the telephoto camera was not originally my idea, and I am not "against telephoto cameras", at least not until Sony implement my request for a higher resolution Starvis 3 21:9 aspect ratio image sensor that will make telephoto lenses more or less obsolete again, which I suspect is going to take a while!
No.A 4k camera with with normal FoV could capture all those plates too.
No.If we are comparing a 4K "normal" sensor/lens with an FHD x2 telephoto sensor/lens, then you should be able to use the digital zoom function of your video player to zoom in to the 4K video and get exactly the same field of view with exactly the same detail.
If you are sitting still at the lights in bright lighting, as in Dashmellow's images, then motion blur isn't much of an issue. If you are driving on bendy UK winter roads, with trees alongside the road and roundabouts instead of lights, so instead of stopping you sweep your telephoto around an arc, with it pointing at the wrong lane, then motion blur is definitely an issue. For my driving, I find that motion blur is most often the limiting factor, for me it is the most important thing to improve. I rarely want more magnification than I can get by zooming into a A129 Pro 4K video.
@TonyM picked up on this concept the last time we talked about this idea. He may well be the first to demonstrate this as a DIY project. I've thought for awhile now about converting my mini-0906 pre-production sample for this purpose but I just don't have the time this time of year. Hope to get to it eventually and see if I can make it work but I usually engage in projects like this during the deepest parts of winter.
So when do you think you can have a Street Guardian Duo wide/tele ready for market? You've already got the essential components!I'd buy one.
Would be a while before we'd have a chance to do that, too many other projects on the go already is keeping us busy
My only rear camera is a telephoto, but that's a personal choice 😛Yes you can not run such a camera alone, it need to be paired with a regular wide angle camera
Gosh, I remember all the discussion back then and all the questions you asked and you even started your own threads about it, so now more than three and a half years later I'm quite amazed to hear that you never completed the project. I thought you were enjoying your modded camera this whole time. Well, you still have the lens you purchased so you could still make it happen. Since that time the 2K M1s was introduced and that lens would work on that camera with not too much effort. 🙂
So, we would need to use this 6m interior camera cable to use the interior camera at the rear?So this takes the rear camera socket, and you either use the interior camera as the rear camera, or use an independent rear camera such as the Viofo VS1 or A119 Mini 2.
Would you be able to share some footages? I wanna see how zoomed in the video is. I hope you can. Thanks.My only rear camera is a telephoto, but that's a personal choice 😛
(it's a 6mm lens)
