DashCamOnBoard
- May 17, 2015
Only if it's tintedI would assume having it behind the windshield would not be direct sun since it provides some protection.
Presuming this is a new warning, haven't seen this one before haha. I suspect this may be partly my fault because I tested the A229 Pro, and it overheated a few times while parked stationary.Now folks, THINK about this.
Any dashcam is GOING to get hot in the car in the summer, especially very hot climates. So what, they expect us to remove the dashcam every day if it's hot out? C'mon, dog.
And they need to fix their grammar. ... , it may cause the camera TO overheat.
Fair point but as with anything electronics, there are constraints. We are paying consumer grade prices for such equipment and not for professional equipment designed to withstand the harshest of climates .They really should be designed to work in high temperatures though...
Well of course that should be the case, but we’re talking about $100 “budget” devices here.They really should be designed to work in high temperatures though...
Pretty much every dash cam from every brand will overheat in direct sunlight in parking mode.Yeah, but it still needs to WORK. If they need to add another $50 to the price to NOT have to put an unrealistic warning in their own manual, then DO IT.
It gets hot in cars. REAL hot. They need to factor that into their research and development.
Like the Thinkware U1000 4K I tested before, while the WiFi is turned on, it will automatically be switched to 2K resolution.Pretty much every dash cam from every brand will overheat in direct sunlight in parking mode.
It's not just a Viofo thing.
The only brands that are really known for hi temp operation are Thinkware & IROAD, (Korean made).
*Shots fired*Like the Thinkware U1000 4K I tested before, while the WiFi is turned on, it will automatically be switched to 2K resolution.
It's the last entry in the FAQ section that contains the warning. The same warning is present in the A229 Pro and A229 Plus FAQ sections.@DashCamOnBoard do you have a link to where that note is on Viofo's site? Do they say the same thing for the A229 Plus?
This tip is for all the dashcams, not only for certain specific ones. Overheating issue is always a hot topic in the dashcam market, and all our manufacturers keep trying to solve this problem. VIOFO also has paid much attention to this to optimize.@DashCamOnBoard do you have a link to where that note is on Viofo's site? Do they say the same thing for the A229 Plus?
It’s an issue for every dashcam, sure, and it’s a tough problem. FWIW I have way better luck with dashcams than I do with GoPros, phones, and mirrorless cameras.This tip is for all the dashcams, not only for certain specific ones. Overheating issue is always a hot topic in the dashcam market, and all our manufacturers keep trying to solve this problem. VIOFO also has paid much attention to this to optimize.
What maximum temperatures are you getting in summer though.If the climate control works, then on the way the sun is not a hindrance, but when parking, I always cover my windshield with a mirror curtain, I’ve been doing this for 15 years and there are no problems!!
