Would you be so kind as to clarify this a bit further? Does this mean that the current behavior has also some other changes cf. the currently published User Manual, and you refer here to those changes?
(I understand the terms "timelapse", "low bitrate", "motion detection", "buffered" etc. quite well, but I'm not sure what exactly are the approaches that are compared here, and where exactly does the term "difference" point here...).
I think I explained it a bit too briefly earlier, so Iâve written it out again in more detail below. Please let me know if anything is still unclear.
With the current firmware, once the
Discharge Cut-Off Time is reached, the device transitions into
ELPM. When the battery voltage then reaches the configured
Discharge Cut-Off Voltage, the device powers off completely.
If an impact event occurs after the device has entered ELPM via the Discharge Cut-Off Time, the camera wakes up, records the event, and checks the battery voltage. Based on the voltage level, it then decides whether to power off or return to ELPM.
Because the power consumption in ELPM is close to
0 mA (not exactly zero, but nearly), it is practically impossible for the vehicle battery to drain unless impact events continue to occur repeatedly.
The key difference I was referring to is how parking-mode recording is handled.
With other brands, parking mode may involve
continuous recording, such as a
low-bitrate recording mode, until a first voltage threshold is reached. At that point, the device may enter a low-power mode, and if the voltage drops further to a second, lower threshold, the camera then powers off.
In contrast, our approach records
only when motion or an event is detected during parking mode. The device transitions into ELPM after a user-defined time, and once the voltage drops to the configured cut-off level, the device powers off. This difference in recording and power-management strategy is what I was trying to highlight.
BTW, are there plans to introduce Vueroid S1 4K 3CH to the European markets in the near future? I tried to search a webstore to submit an order but have not succeeded in finding one that would dispatch to Europe so far... From everything what I have read and seen so far, it looks exceptionally promising, and I'd be interested in getting one into my hands.
We are grateful to see continued interest and inquiries about purchasing our products in Europe. While we are actively working to identify local distributors within the region, we are also preparing our own online store as the fastest way to make our products available. We will be sure to share updates as soon as everything is ready. We apologize for the wait and truly appreciate your patience.
