lufa6977
- Jul 22, 2024
- Virginia, Shenandoah Valley
- United States
- Vueroid S1-4K, Viofo A129 Pro Duo, A229 Pro, IR, Telephoto
I know.
I do not think it is a matter of the amount of light, my H4 55 W bulbs are plenty strong i think, but the light from them in low beam only go into the other lane up to 5 M or so in front of the car, i simply can not capture plates with S1pro Max or T 800.
But if i put on high beam and adjust those all the way down so i at least do not fry the retina on oncoming drivers i am catching plates just fine, even have several frames to choose from, Okay the light of the high beam are stronger alright, but i think more important it is thrown into the oncoming lane some 15 M and further out ahead.
If i was younger and more fit i would load several 100 kilos of stuff into the boot of my car to get the low beams higher up to test if that made a change.
That is too much work for us old men. Just install one of those lowrider hydraulic lift systems; you will be able to jack that front end up to whatever height you want. 🙂
