Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A229 Pro TeleQuad (the best dashcam in the world!)
If the card is genuine it should have a (lifetime) guarantee. I would check the Transcend site and see if you can send it back for replacement. I did this with my Sandisks and there was no problem.My Transcend Premium 300X 64GB worked just one day. Now is in read only mode and I cannot recover it. Money lost.
enjoy,
Mtz
I was trying to format it with a lot of PC methods, programs, dashcams, android smartphone, kept in refrigerator for some time, etc...Although I never succeeded myself, some people were able to recover from the 'read-only' state by formatting their card with different programs/format parameters.
Your old cards will work perfectly! Unfortunately, back in, maybe 2011-2012, Sandisk started using a badly designed/badly tested controller, most likely in an attempt to obtain a faster throughput. If the card is stressed it will fail. 'Stressed' could be due to heat. All my Sandisk cards failed after extended recording times. Some cards just flipped permanently to read-only, others became non-readable. A Sandisk tech once told me the read-only flip was 'by design' to prevent a total loss of data. I have also had a Sandisk fail simply by reading it in my card reader! I can't remember exactly how many failed Sandisks I have had, but I think it's in the order of 5 or 6. I have never had any other card fail even though most of my cards are other brands. All my cards are genuine.Just a question, whats wrong with the SanDisk controllers? Do these cameras not like the SanDisk controllers in their SD cards? Or is it because these devices were not built for the new higher standards these controllers offer, thus creating issues and people blaming the SD card manufactures?
In the photography business SanDisk SD cards are the recommended choice for a majority of professional photographers and videographers using Nikon/Canon devices.
I own several SanDisk cards, some dating back to 2007, still working just fine. Mind you I don't buy them online simply because of all the fakes you hear about.
I would guess that the overwhelming proportion of their MicroSD business is in smartphones where they don't get the flogging that they do in a DVR, quite astounding that any card stands up to some of the 24/7 usersI know Sandisk (still) have a good name, but I don't know why - maybe because they are fast and failure rates aren't important? Or maybe they work OK when when they don't have to run in a confined area where heat could be a problem?
Before about 2011/2102 Sandisk were my favorite brand, but now I wouldn't even use one if I was given one for free, except for testing of course. The risk of losing all my data is just too high. I do, however, have a 128GB Sandisk, but I dread using it....
You probably have already seen this but it could be that SanDisk was first to manufacture microSD cards according to this wiki, provided it is correct. Scroll down to history.I know Sandisk (still) have a good name, but I don't know why...
I don't favor any cards - I just disfavor Sandisk! Having said that, most of my cards are 32GB Kingston from different batches. I have also tested other 32GB brands such as Samsung, PQI and PNY.Good explanation. I wasn't aware of this. How about Samsung SD cards? do they have the same type of controller design? I see Kingston is highly recommended on here because of reliability. What others would you favour?
I tested the cards using firmware that I knew used different chip manufactures codes and found Kingston cards to be the most reliable. No cards, except Sandisk, failed physically.
If reliability is important then I recommend class 4, but even class 4 can have their quirks and the newer Sandisk class 4 are just as bad as class 10. The original (first) Sandisk class 4 were great, but then they changed their controller...
I use an Anker Astro E4 13000mAh. Other brands are available. The most I've done is to use my Anker to power Mobius overnight when my car was in a hotel car park. After around 10 hours use from fully charged, 3 of the 4 charge indicator LEDs on the Anker were lit, indicating it still held between 50% to 75% charge.
I am using Sand Disk "OH THE HORROR!!!"
...whether the the standard battery can be left in the Mobius, or whether it has to be removed and replaced by the capacitor, just seems odd that all other phones and tablets don't have a problem with external power packs.
Power Banks can be used with Mobius with it's own battery installed. The minimum output of the power bank should be not less than 5V/1A & the two you've ordered exceed the requirements.
Threads relating to Power Banks can be found at...
https://dashcamtalk.com/forum/forums/batteries-and-capacitors.87/
Contributors like @Dashmellow have much greater in-depth knowledge of this subject than I do.
...128GB Sandisk SD card on FAT32 using the Disk Utility app on my Mac, and have left it running tonight in the Mobius to see how long it records for before it loops around to overwrite the oldest video footage...
Roughly 16 to 18 hours depending on whether Data Rate is set to Standard or High.
