- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
putting motion detect on may cause you to miss things when it should actually be recording
by mileage you mean how far will i get with it/how reliable the card will be over time, or will i have any success at all or not at the begining?You can get the TFTec adapters from DX.com - I tried one with a 128GB KomputerBay card and it worked fine in my X2 - your mileage may vary in the Mobius though as it can be picky with cards it works with
http://www.dx.com/p/sd-to-microsd-transflash-card-converter-module-27001#.VS6tz1J4XCQ
i would like a single large card so i have couple of days to notice damage on car and still have the footage on the card, other usage would be having full 15hours of parked footage, in case i ever get a full time job(8hours + time to and from the car)They're all the problems with this route to be honest - I did look at some alternatives on eBay but the only neat solution is to use microsd cards - you can see the Sandisk Uktra 128GB seems to work ok and to be honest there aren't that many to choose from in that size.
Do you need a single huge card or could you use multiple smaller ones? I took a load of 32GB ones with me on holiday and swapped them over when they got to around 3 hours of video.
someone here already tried it exact combination dx adapter + qumox sd if i recall corectly, for several months without issues, but i cannot find the topic/post againFor long term use I wouldn't recommend an adaptor in case anything does go wrong - I did some benchmarking and cards are definitely slower through the adaptors anyway - how they'd last long term in anyone's guess.
Mine worked fine for a week but I didn't quite trust the Komputerbay card I had so it went back.
If you do try this you'd probably be the first person to try them in the Mobius - someone has to be the guinea pig
you should have told me this last night, the card and the adapter are already shippedMy tests with a similar adapter were never really successful. The micro SD part of the cable doesn't make a very good connection and can easily fall out. It may work better if it's well secured with tape but I wouldn't use it if reliability is important to you.
I never tried it with a 128GB card though. My tests were done on my workbench. I wouldn't want to use it where movement is involved. Your adapter may be better than mine where the connection part was too thin.
In the meantime I'm waiting for the prices of 128GB micro SD cards to drop to an acceptable level. They've come down a bit over the last month or two but for me they're still too expensive to play with.
That's exactly the same adapter I have (TFTEC) . But maybe you'll receive an improved version. Also, one of my adapters didn't work initially - there was a bad solder joint...you should have told me this last night, the card and the adapter are already shipped
i was relying on this
http://www.rcgroups.com/forums/show...d77a695256a4a8df4e0&p=26436043&postcount=4016
+ some luck
so TFTEC+128GB fullSize SD card works fine, loops fine,That's exactly the same adapter I have (TFTEC) . But maybe you'll receive an improved version. Also, one of my adapters didn't work initially - there was a bad solder joint...
It will be interesting to hear your results.
I'm glad to hear the TFTEC adapter works for you. The same adapters didn't work well for me at all. They were not reliable, possibly because of the bad contacts at the micro end.so TFTEC+128GB fullSize SD card works fine, loops fine,
BUT only with v1.13 Firmware, anything newer does not work
could it be fixed in the newer FW, is there some FW request thread ?
I have tried combination of tftec adapter and a 128gb master SD and a 256gb PNY SD card in a variety of players Ibasso dx50 and dx90 , fiio X3ii, sony A15 and the 128gb worked fine in all 4 while the 256gb was not recognized by the dx90 but was by the dx50 and fiio - been using for 4 months no problems and much cheaper than microsd card option for now until price comes down - have not experienced any speed problems and have not had any connection problems once i folded back around to back of player under cover of player being used - so far so goodsomeone here already tried it exact combination dx adapter + qumox sd if i recall corectly, for several months without issues, but i cannot find the topic/post again
