There's no trolling, just a difference in opinion.
As for dashcam perfection, one thing that is immediately obvious when you look at the Ribcage modded lens, is that the lens is a major restricting factor on many cams. Yes they're built to a price.
However, look at this way, if an OEM manufacturer were to design their standard lens base as an M12 screw socket, then there would be no ribcage mod necessary, and a better lens could be fitted as standard. A 16-18mp resolution 4K low distortion lens is still around $100 retail. However, on the basis of the usual markup of 100% these days, that's $50 trade. So for a price increase of $50, pretty much any dashcam manufacturer could in theory turn out an OEM M12 cam with one of these accessory lens as the standard lens for around $50 more than their current model (maybe a little less with volume purchasing of the lens). Something with a 70-90 degree view would be ideal (in the 2.7mm - 4mm range). It would also give the end user the option of changing the lens for a different one if their needs required a different angle of view, if the base was an M12 screw. Win win for both as changeable lens is a USP and better quality for end user.
