Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- United States
- Umpteen
Make sure you fix the dim LED issue. This is vitally important without a screen to see the status. This also the only issue that must be done in hardware so is impossible to fix once the custolmer has the camera.
There are two reviews of this camera on Amazon and both give it 2 out of 5 stars due to the dim LEDs. It should be he easiest to fix with an LED or resistor change. Unless they are being pulsed through firmware and need a longer on time.
@jokiin mentioned earlier in this thread that the LED brightness on the WR1 might be addressable via a firmware update.
