with this set up output remain in 4:3 not superview...
...looking for a free software testing upscaling from 1280 x960 to 1920x1050 because shotcut is crashing on my win7 32 bit system while loading plugins.
Any idea?
...yes i tried with same result@gente did you tray an older version of Shotcut for 32bit? Here for example v15.08 https://github.com/mltframework/shotcut/releases/download/v15.08/shotcut-win32-150811.exe
ffplay or ffmpeg via command line?...looking for a free software testing upscaling from 1280 x960 to 1920x1050 because shotcut is crashing on my win7 32 bit system while loading plugins.
Any idea?
Nice job man... gimbal works really good, did you try it to let all fly up or is still too heavy?...yo Fried, what's up my buddy π I'm back, not with a new firmware or else but with this:
Hope you'll enjoy the video and you all know that I'm an idiot so don't laugh at me so much π , but anyway I did my dream come true by mounting this heavy Gimbal on this underpowered poor V262 and next thing that I'll do to cut the anti vibrations plates from carbon fiber and will remove the current aluminum .... hope will release another 10-20 g in the perfect life situation and the quad will become even more lighter π wish me luck and .... I know that even that I'm shooting directly in the sun the video looks gorgeous ... well this is the moment to say big THANKS to Fried, he is the quilty one to make all of us so happy by giving us this firmware π
sandisk extreme: 60/40MB/s
sandisk extreme pro: 95/80MB/s
sandisk extreme plus: 80/50MB/s
you have pro version?
the second value is write speed, the first for reading!
but the normal version with 40MB/s write must be fast enough for 35mbits.
I have the plus and until now no problems with 35mbits, but i had to split not more than two times because my filesplitting is set to 4gb by script, no longer videos than 30 minutes.
45mbits with 2,3k 30fps and 1920x1080 60fps i have same behavior like you.
That's OK, everyone was a Newbie sometime.
Question 1.... Read the FIRST post on page 1 of this thread. Be sure to use the firmware for your Z22L camera.
Question 2....Right click on the video file. Select properties, select Details tab.... You should see Frame width, frame height, data rate, total bitrate and frame rate. My OS is Windows 10.
Question 3....This requires running scripts. Read all posts on this forum concerning using scripts and you will be amazed.
EDIT Johnnybf unzip this and copy it to your sdcard root. Should give you Raw + Jpeg.
