Download this file:
https://mega.nz/#!iQF0mYoT!pqn4x1AtrlRXNTEGT4WD7PBjAuE97KJZnpb2OUl_rUg
MD5SUM: 1a644d309779d9a8b4b327c5b82762ca
This file contains a full instruction from Xiaomi support. Read this first. I will add my extra items to instruction.
This instruction is for 22 and 22L revisions. Choose the correct ELF file from the archive.
Instruction:
1) Unmount the front panel.
2) Install the program from archive (kind of DirectUSB program ).
3) Connect camera to PC.
4) Run installed program.
5) Check "Upgrade Firmware" radio button
6) On this step you need to short-circuit 2 points of camera - main board (GND) and the point above the resistor - look at the instruction in the archive. Resistor marked by red color in the PowerPoint file in the archive.
7) KEEP these 2 points short-circuited and press Power button to enable the camera. This turns the camera in the DirectUSB mode.
8) Press "Connect" button in the program.
9) Choose correct ELF file and press
10) Press "Download"
11) Wait for "Done" in the programm
12) Wait few minutes for 3 beeps (I do not remember them, but it is better to wait few minutes).
13) Disconnect you camera.
On this step you should get a working camera. Also I downloaded and installed the latest firmware from xiaoyi.com/upgrade after everything, but I do not think that it is necessary.
If everything is OK you will get this message in the program: "Found 1 YXDJ device". If you get "Found 0 YXDJ" then something is wrong. Try to remove the battery and repeat 6, 7, 8 items.
You it doesn't help then try it in the next order:
- 6)
- 7)
- Do not release power button, keep it pressed
- 8)
- Got "Found 1 YXDJ device"
- release power button
Instruction:
- 6)
- 7)
- 8)
