Samsung EVO 64GB in theory should work great, but I'm reading that with high bitrates it does not. I was going to buy the EVO, but now I'm a little bit confused, does the EVO work great or should I buy the PRO? If it's not needed there is no reason to waste the extra money that costs the PRO version(Plus the shipping cost of amazon, because they don't sell it where I live).
Thanks in advance!
here is Media info of my GoPro Hero 4 file, the EVO 64GB worked great:
I used this tool to format it:
http://www.rcgroups.com/forums/showpost.php?p=30748027&postcount=1022
General
Complete name : D:\GOPR0003.MP4
Format : MPEG-4
Format profile : Base Media / Version 1
Codec ID : mp41
File size : 120 MiB
Duration : 16s 683ms
Overall bit rate mode : Variable
Overall bit rate : 60.4 Mbps
Encoded date : UTC 2014-12-01 13:22:40
Tagged date : UTC 2014-12-01 13:22:40
AMBA :
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 1 frame
Format settings, GOP : M=1, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Bit rate mode : Variable
Bit rate : 60.0 Mbps
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.241
Stream size : 120 MiB (100%)
Title : GoPro AVC
Language : English
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Full
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 40
Duration : 16s 661ms
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 261 KiB (0%)
Title : GoPro AAC
Language : English
Other #1
Type : Time code
Format : QuickTime TC
Title : GoPro TCD
Language : English
Other #2
Type : Time code
Time code of first frame : 13:21:51:26
Time code, striped : Yes
mdhd_Duration : 16683
Bit rate mode : VBR
