How higher the writing speed of a MicroSD card, the better it is ofcourse. Yi support up to 64GB Class 10.what's the top write speed microsd Yi support? class?
Very cool when it works, eh?
Realize that if you choose another resolution from the menu choices, you'll lose the 2304 option. It's not persistent and doesn't appear as a menu choice. It only is available just after a reboot.
... and now it doesn't work any more.
I even added the extra blank line at the end like mentioned above, still no joy.
You use Windows, right? I use Macs.
The program (or app) I use to edit the autoexec.ash files on my Mac is named Sublime Text. It produces Unix compatible files like those needed to edit and create the script files for this camera.
You can download a Windows version of a free trial version of Sublime Text from the Sublime Text website here. But, if you browse through this thread, you'll find mentioned several other Windows apps that are recommended. I believe if you use the right text editor, you'll solve the problem you're having.![]()
... I save the copy of your .ash file before using it, so I could put a 'virgin' copy on the SD card every time if I needed to ...
Shouldn't need to do that. the .ash file is not altered or deleted from the card unless you do it.
Well, I didn't change anything and the .ash file doesn't do its trick any more unfortunately.![]()
You can still download the attachment I posted earlier and try that if you don't still have at the .zip file.
Yikes!Okay so I downloaded that Zip file again, unzipped the .ash file again, put it on the SD card again ..... and now it works, again.
Beats the crap outa me .....
Hello, first post here with a request :
Is there a script which 1 second after starting the camera, captures a photo and then switches and waits in record mode.
Also, is there a way to take pictures while capturing video ?
sleep 9
t app key shutter
sleep 2
t app key cap_rec_switch
sleep 3
t app key record
just wondering what extacly does the sharpness scrip do? how does it make things sharper and for what distance does it do things sharper?
sharpening script:
#t ia2 -adj tidx [ev_idx][nf_idx][shutter_idx]", "-1 disable"
#looks like the values are between 0-16383 (0x0000-0x3FFF)
#set noise reduction value to 2048
t ia2 -adj tidx -1 2048 -1
Since you're posting to a thread about scripts, I'll assume you already have the appropriate script. If not, just say so.How to use 1080p 30fps 35mbits v1.2 firmware? my modell:Z23L
