emailcraigs
- May 20, 2015
Has anyone messed with or had success with the noise reduction script to increase sharpness? If so what setting did you use?
Not really, I have tried to append the noise reduction script to the 35M 2304 file that was download from funnel, the cam went back to 1080p when startup. No solution at the moment.....you can combine ANYTHING in the .ash script. You can even make camera beep a rhytm of your favorite song.
If it is the case, can you share your script with me? Screen shot is good enoughIt works for me, my camera is running firmware version 1.20 and it can take 2k videos with noise reduction perfectly.
#set video resolution to 2304x1296 30fps
writeb 0xC06CE446 0x02
#set bitrate to 30Mb/s
writew 0xC05C1006 0x41F0
#set noise reduction value to 2048
t ia2 -adj tidx -1 8192 -1
Oh oh, this is just for 1.20 firmware, NOT for the older ones. If you have a different version, you need to change the 2k video setting code to a correct code.If it is the case, can you share your script with me? Screen shot is good enough
Thanks for your reminding, I am using fw1.20 already.Oh oh, this is just for 1.20 firmware, NOT for the older ones. If you have a different version, you need to change the 2k video setting code to a correct code.
Thank you very much, let me have a try.I just increased the value to 8192 instead of 2048 and it works.
does this new video resolution appear in the Yi menu ?#set video resolution to 2304x1296 30fps
Tried to do it in PSPad editor, there is UNIX option in format but after clicking on it it's not checked. Solution?BTW you need to save it as a UNIX text format, not the DOS/Windows one.
You may need a 3rd party editor for editing the code and save it, like Notepad++ in Windows or TextWaggler in OSX.
