As far as I know, no one has yet found a provision in the camera for changing the frame rate (fps).is it possible to hack settings to shoot at the full (16 mpix) resolution but with lower fps (e.g. timelapse videos)?
it is even okay, if camera will produce a separate image files at 16mpix/ 2fps -- is it possible?
The 1080/60 resolution is already enabled in firmware version 1.2.12, so you can remove the "writeb" line altogether. You don't need to enable it again.can anyone tell me lines for 1920/1080 30Mbps 60 fps for 1.2.12
i did try with this
#enable 1080p60@30Mbps video
writeb 0xC06CC426 0x02
writew 0xC05C1EE2 0x41C8
I think that writeb line is wrong, can someone help me ?
The "writew" line sets the bitrate for that resolution and the value you have there (0x41C8) is for 25Mbps.
Change that to 0x41F0 (30Mbps) and it should work as you wish.
Be sure to use a proper Unix text editor to make the changes.
Try playing with metering mod optionHi,
I am using Xiaomi Yi with firmware 1.12.12 as a DashCam. With day light, the quality is great with 2K resolution and 30Mb/s. However, when driving at night, the reflection from the car plate of the front car always too strong. Is there any hack can tune down the exposure or brightness or contrast so that to reduce the reflection effect.
I borrow my friend's SJ4000+ with default settings. At night drive, the video is a bit darker than the Xiaomi Yi but the reflection from the car plate of the front car is much better.
rgds,
rlpc8
Try playing with metering mod option[/QUOTE
Tried, doesn't help.
How to identify its version?Do you have a "L" version?
Thanks for your advice. I have checked the number, the fourth character of the Serial Number is a numeric letter. Is it a defective batch?Look under the battery cover, you will see serial number. ZXXY.... if Y letter is "L", than you have the "L" version 🙂
Dear Sir,The question was about "L" version because they has not the IR filter installed on the lens.
So you can be proud of your fourth character to be digit, because your lens has IR filter 🙂
