Has anyone tried a production mini 0806 CPL with the new lens?
I might just buy a new one, but not if it is still going to cut the corners off, which looks a possibility!
OK I found out why mine isn't saving last files - one of the solder connections is broken on the capacitor :/
It seems more people are fixing than testingSo how many DCT members are testing this camera, anyway?
It seems more people are fixing than testing(I'm waiting for parts)
Frankly, I expected much better QA on these samples. I know it is not possible to check every item when in high volume production, but when sending samples to testers, they should ensure that every single camera is functioning properly. How can a camera be shipped with broken mic or RTC that resets every couple of hours?As I alluded to earlier in the week and with the way things seem to be going here what with everyone hip-deep into major camera tear-downs and repairs which may include removing and re-soldering a tiny component to the pcb, re-seating very small ribbon cables and ensuring lens module alignment and focusing, I really have to question how the testing results that come afterwards can be a valid representation of the product that will be coming off the assembly line. Performance results and potential glitches and anomalies that manifest may no longer be an accurate reflection of the original product.
I appreciate the expense and logistics involved for MEG shipping these pre-production camera samples all over the planet but I almost feel like there is a need to select a small group of testers and start over.
Just sayin'.
It will be helping to find issues and improve the production units, for example the cause of Reverend's corrupt files would not be known if he hadn't stripped the camera down, and a couple of us found trapped ribbon cables which may cause unreliability if it reaches production. If we had simply been shipped replacement units these issues would have gone unsorted.As I alluded to earlier in the week and with the way things seem to be going here what with everyone hip-deep into major camera tear-downs and repairs which may include removing and re-soldering a tiny component to the pcb, re-seating very small ribbon cables and ensuring lens module alignment and focusing, I really have to question how the testing results that come afterwards can be a valid representation of the product that will be coming off the assembly line. Performance results and potential glitches and anomalies that manifest may no longer be an accurate reflection of the original product.
Just sayin'.
This should be the same flexi cable, and sort of same camera angle too.
When you snap shut the locking "lever" then it should be a little tight when the damn thing are properly seated, then again i also thought it was that when i struggled with it.
But you are correct that they may no longer be representative of the production ones, especially with some of us using Tobi@s's bitrate upgrade. Someone will have to review the production units to find the truth about those and until someone does it is going to be hard to recommend the camera, we can only recommend (or otherwise) our modified cameras. The same is true of the 0806, mine is still working fine after 2.5 years use often sitting in full summer sunshine with no shade, and still with bitrate enhancements, and still on the original battery, certainly not representative of the production units!
That is always a bad signI wonder where these extra screws go?![]()
That is always a bad sign![]()
AbsolutelyWe've probably all been there at one time or another.![]()
