- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
here's a link for reference https://en.wikipedia.org/wiki/Flame_treatment
it's not the heat, you need the flame, same process won't work with a heat gun, same process is often used on plastics that need to be painted so that the primer/paint will stick without issues
I would imagine if you get the plastic hot enough to melt or nearly melt with a heat gun it would have the same effect as a flame. My heat gun can start things on fire quite easily if I don't pay attention.
Interesting. I think a $150-$200.00 dash cam shouldn't require such heroic measures on the part of the customer, especially as the tape generally comes pre-applied to the mounting plates. Maybe it's a thing that should be done at the factory if it's such a problem?
Yes! I have this problem as well, I cleaned the glass with acetone then good glass cleaner but when a bit of heat it comes off.Anyone else had a problem with the pads not sticking to either the windscreen or the mount?
A few weeks back the mount came away from my windscreen. The sticky pad was still attached to the mount but it had come clean away from the screen. I stuck another pad onto the existing pad and put it back on the windscreen. Yesterday the camera was hanging by the cables again but the sticky pads were still attached to the screen but they had come clean off the plastic mount.
Any ideas on something stronger so this doesn't keep happening?
You are right Acetone is strong stuff and will dissolve some plastics and other materials so it is a a good idea to test a insignificant area first, other than those materials it is suppose to remove films then evaporate completely though I will clean afterwards with another cleaner like alcohol to be sure.I was told to use acetone to clean optical sensors at work, but I used isopropyl alcohol instead because I had that already. I never got round to buying acetone because the alcohol did a perfect job. But I've seen a lot of cloudy looking sensors and I suspect acetone is sometimes the culprit (dissolves more than just the dirt?) Also it might leave behind residue. I wouldn't be surprised if the nail varnish remover variety has added oils for example.
Sent from my SM-G903F using Tapatalk
Don't bother with the supplied pads. I tried the first one (cleaned glass with glass cleaner etc first). Came off the 2nd day. Stuck it back on, was falling off later the same day. Used the second pad in the box, fell off 2 days later.
I had some auto-trim tape in the shed. Hasn't moved in a month. Auto trim tape is the stuff they use to stick plastic trim (etc) on to body panels, and it seems to work great. Also very cheap from most auto-stores.
