WA3PNT
- Jul 29, 2016
- Chino Valley, AZ USA
- Thinkware F750/770 Firmware (Dual), X550 (Dual) and a F50
So this turned my attention to the SD Card Adapters and their performance (or lack of performance).
I found the following:
These Adapters returned similar, lower CrystalMark Results:
OLD Thinkware Adapter
NEW Thinkware Adapter
SURPAK Adapter
These Adapters returned similar, higher CrystalMark Results:
LEXAR Adapter
ROCKETEK Adapter
Based on the Adapter findings, I re-tested all the SD Cards using the LEXAR Adapter. All Cards were tested three times, and each Card returned very similar results.
Below are the Crystal Mark test results for the SD Cards using the LEXAR Adapter:
Thinkware X550 32GB
CrystalDiskMark 5.1.2 x64 (C) 2007-2016 hiyohiyo
Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 bytes/s [SATA/600 = 600,000,000 bytes/s]
* KB = 1000 bytes, KiB = 1024 bytes
Sequential Read (Q= 32,T= 1) : 92.616 MB/s
Sequential Write (Q= 32,T= 1) : 48.189 MB/s
Random Read 4KiB (Q= 32,T= 1) : 8.068 MB/s [ 1969.7 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 1.505 MB/s [ 367.4 IOPS]
Sequential Read (T= 1) : 92.914 MB/s
Sequential Write (T= 1) : 47.401 MB/s
Random Read 4KiB (Q= 1,T= 1) : 7.606 MB/s [ 1856.9 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 1.229 MB/s [ 300.0 IOPS]
Test : 500 MiB [F: 0.1% (0.0/29.8 GiB)] (x5) [Interval=5 sec]
Date : 2017/03/29 18:20:53
OS : Windows 8.1 Pro [6.3 Build 9600] (x64)
Thinkware X500 32GB
Sequential Read (Q= 32,T= 1) : 92.541 MB/s
Sequential Write (Q= 32,T= 1) : 48.762 MB/s
Random Read 4KiB (Q= 32,T= 1) : 7.988 MB/s [ 1950.2 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 1.196 MB/s [ 292.0 IOPS]
Sequential Read (T= 1) : 92.497 MB/s
Sequential Write (T= 1) : 47.819 MB/s
Random Read 4KiB (Q= 1,T= 1) : 7.481 MB/s [ 1826.4 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.791 MB/s [ 193.1 IOPS]
Test : 500 MiB [F: 0.5% (0.2/29.8 GiB)] (x5) [Interval=5 sec]
Date : 2017/03/29 19:06:17
Thinkware F750 16GB
Sequential Read (Q= 32,T= 1) : 93.176 MB/s
Sequential Write (Q= 32,T= 1) : 26.815 MB/s
Random Read 4KiB (Q= 32,T= 1) : 8.459 MB/s [ 2065.2 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 1.431 MB/s [ 349.4 IOPS]
Sequential Read (T= 1) : 93.332 MB/s
Sequential Write (T= 1) : 26.426 MB/s
Random Read 4KiB (Q= 1,T= 1) : 8.009 MB/s [ 1955.3 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 1.180 MB/s [ 288.1 IOPS]
Test : 500 MiB [F: 1.9% (0.3/14.9 GiB)] (x5) [Interval=5 sec]
Date : 2017/03/29 19:13:10
Thinkware F50 8GB
Sequential Read (Q= 32,T= 1) : 24.095 MB/s
Sequential Write (Q= 32,T= 1) : 11.639 MB/s
Random Read 4KiB (Q= 32,T= 1) : 6.665 MB/s [ 1627.2 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 0.927 MB/s [ 226.3 IOPS]
Sequential Read (T= 1) : 23.910 MB/s
Sequential Write (T= 1) : 11.536 MB/s
Random Read 4KiB (Q= 1,T= 1) : 5.770 MB/s [ 1408.7 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 0.979 MB/s [ 239.0 IOPS]
Test : 500 MiB [F: 90.8% (6932.4/7631.0 MiB)] (x5) [Interval=5 sec]
Date : 2017/03/29 19:21:34
LEXAR 633x 64GB
Sequential Read (Q= 32,T= 1) : 93.962 MB/s
Sequential Write (Q= 32,T= 1) : 25.481 MB/s
Random Read 4KiB (Q= 32,T= 1) : 7.315 MB/s [ 1785.9 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 1.269 MB/s [ 309.8 IOPS]
Sequential Read (T= 1) : 94.383 MB/s
Sequential Write (T= 1) : 28.526 MB/s
Random Read 4KiB (Q= 1,T= 1) : 6.890 MB/s [ 1682.1 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 1.127 MB/s [ 275.1 IOPS]
Test : 500 MiB [F: 7.6% (4.5/59.7 GiB)] (x5) [Interval=5 sec]
Date : 2017/03/29 19:28:28
SanDisk ExtremePLUS 128GB
Sequential Read (Q= 32,T= 1) : 94.906 MB/s
Sequential Write (Q= 32,T= 1) : 89.170 MB/s
Random Read 4KiB (Q= 32,T= 1) : 9.408 MB/s [ 2296.9 IOPS]
Random Write 4KiB (Q= 32,T= 1) : 5.191 MB/s [ 1267.3 IOPS]
Sequential Read (T= 1) : 95.222 MB/s
Sequential Write (T= 1) : 89.761 MB/s
Random Read 4KiB (Q= 1,T= 1) : 8.832 MB/s [ 2156.3 IOPS]
Random Write 4KiB (Q= 1,T= 1) : 4.946 MB/s [ 1207.5 IOPS]
Test : 500 MiB [F: 9.4% (11.2/119.1 GiB)] (x5) [Interval=5 sec]
Date : 2017/03/29 18:07:02
I have tried the SanDisk ExtremePLUS in my F750 (running F770 Firmware) and in my X550 and the Card was accepted, could be formatted in the DashCam, and appears to operate correctly.
I currently have the 128GB Card in my X550, and will run it overnight. In the morning, I will find out the length of time that the Card will record in the Continuous Record Mode before overwriting. I will also sample the Video Files to see if there are any errors.
After that, I will find out the length of time that the Card will record in the Parking Mode before overwriting.
I still have a SanDisk Extreme (P/N SDSQXVF-128G-GN6MA) and a PNY U3 Pro Elite (P/N P-SDUX128U395PRO-GE) inbound from AMAZON. These Cards were due here on Monday, but were "lost" in shipment. AMAZON is re-sending the order.
I will report on those Cards when they arrive.
So now you have "the rest of the story".
RodeoGeorge
SURPAK Adapter
LEXAR Adapter
ROCKETEK Adapter
Thinkware X550 32GB
Thinkware X500 32GB
Thinkware F750 16GB
Thinkware F50 8GB
LEXAR 633x 64GB
RodeoGeorge
