70mai Firmware Update (changing from Chinese to English)
stuff.hunter
Ireland
70mai Pro + GPS, 70mai
Does it use English voice commands as well ? Cheers
Sent from my SM-N950F using Tapatalk
edie209
I just want to say thanks I have two of these cams and now they work in English.
dactaroye
joined this forum just to say thank you to everyone who has contributed and helped us all to convert the chinese version to english version thank you once again from CANADA
edie209
When I updated my two cameras they took about a minute to update. One thing I did notice is the sd card gets formatted in the process so for the second camera I had to reformat and recopy the file over.
Arruda
Portugal
So... i think i've bricked the cam, i have the chinese version and try to update to v1.04 english version, after that when i try to turn on the cam, olny do a red led, and do not turn on the cam.
Can someone help me?
stuff.hunter
Ireland
Mines won't power up at all, blamed GearBest and waiting for replacement
yippy
Mini 0801 - G1W-C - Xiaomi 70mai
Did you try resetting it with the reset button?
stuff.hunter
Ireland
problem solved :) got English version (ROM 128MB) and works like a charm with full voice control ... on the top of that, received my replacement for bricked one so will use it as rear window recorder :) happy days
sSharonV
Israel
Just finished to flash the english version - and just after the first reboot it talked in english without any surprises ;)
Would you make a torturial for how to adjust the voice recogniztion to other languages?
THANK ALOT!
keenox
Romania
Thanks a lot for the modded fw, guys!
I am curious if the official international fw needs the 128mb flash or it could work on the chinese version also. I would like the english voice commands.
stuff.hunter
Ireland
THANK ALOT!
If you flash Chinese version with English voice, it will lose any voice recognition and as far as I'm aware, there's only English version with voice recognition but it got different hardware - 128mb ROM in compare to 64mb in Chinese version
stuff.hunter
Ireland
Thanks a lot for the modded fe, guys!
Read above
KARY
Poland
Do you have any idea to use the camera button to mark the video as an event?
No video mark function in my opinion is the biggest drawback of this camera.
stuff.hunter
Ireland
it will trigger event mode with g sensor activated but not sure about button so check manual
KARY
Poland
The original firmware does not have this function. I was hoping that a modification is available.
stuff.hunter
Ireland
Really not sure mate, I'll check when get home and will let you know then
stuff.hunter
Ireland
nope, no button recording. i'd try to set g sensor to high and give it a gentle tap, it should work :)
Similar threads
