Dashmellow
- Sep 22, 2013
- Uncanny Valley (●_●)
- Umpteen
So who's going to take the plunge first then![]()
You need to use a 32GB card or less for the firmware update, premsuably because it expects it to be FAT32.
If you already have v2.0 all you have to do is follow step 7. Once the firmware is on the root of your SD car then simply put it back in the camera and power on, no need to reconnect the camera to the computer.
Do you mean the 32GB or less memory card is used as a "temporary" tool to update the firmware to the dash cam? Once it is updated, I can re-use my 128GB memory card?
You can use any spare card or the 128GB one you're currently using.
Always format the card using the format option in the camera's menu and reset to defaults after any firmware update.
That's because normally with new versions of Windows OS, there's no option to format a card greater than 32GB as FAT32.
The .BIN firmware file is deleted from the SD card once the update is successfully completed.
You don't need to format the 128GB card but it's recommended to do in-camera formats once in a while to reset the file allocation tables.
Oh I see. I am using Window 10, let me try it tonite.
So what you are saying is I can use the 128GB card instead of the 32GB or less to update the firmware right?
Anyway, thanks.
Yes, as it's already FAT32 if formatted in the camera earlier.
Do format the card using the camera's format option once completed and reset to defaults.
I just did some quick research regarding the FAT32, you are right the FAT32 is only applicable up to 32GB memory card, other higher than this 32GB, it will be the EXFAT.
So, for my 128gb card, you are saying insert my 128gb card to the dashcam using "FORMAT" button (re-format the card - - - > clean / erase all files) and download the latest firmware file (.bin file) from Viofo using the computer, then insert the format 128gb card to the computer.
Next copy the file to the card (root of the card), then put it back in the camera and power on, no need to reconnect the camera to the computer.
Turn the Power button on and let the dash cam update the firmware (for a couple of minutes I assume), THEN RESET THE DASHCAM TO DEFAULT.
After this, I can customize the setting that I desired.
Please correct me if I am wrong, thanks.
there is no need to reformat a SD card when this SD cad is already formatted and readable by the dashcam, you have just to put in your current SD card the firmware file, in the root of the SD card,
and you can use your 64 or 128 Gb sd card for the firmware flash procedure, as long as your dashcam can read your sd card then all will be Ok
Correct.
For formatting cards larger than 32GB on the computer to FAT32, use this - FAT32-Formatter - https://www.dropbox.com/s/6chif890npunjo1/FAT32-Formatter.rar?dl=0
