- Jan 27, 2013
- Australia
- Too many ¯\_(ツ)_/¯
Are you using Timelapse? In Timelapse, the camera will beep every time a new file is created.
How did you “fix it”? Does it not do this in the latest firmware update?It is fixed.
disable Timelapse lolHow did you “fix it”? Does it not do this in the latest firmware update?
How can the latest software be downloaded from net and can it be installed in earlier A119 and A119S?
Each model dashcam has its own firmware versions. The A119 1440P 2K resolution firmware will not load on the A119S 1080P DVR. Watch my How To Update Firmware video posted higher on this page.How can the latest software be downloaded from net and can it be installed in earlier A119 and A119S? I got one as a gift from one well-known member here, hence the enquiry.
can I flashEach model dashcam has its own firmware versions. The A119 1440P 2K resolution firmware will not load on the A119S 1080P DVR. Watch my How To Update Firmware video posted higher on this page.
No it won't work and you shouldn't attempt it. There are differences in the firmware code specific to each VIOFO Dashcam model, never mix and match!can I flash
VIOFO A119 PRO
to a119?
lol I will not. Just asking for fun.No it won't work and you shouldn't attempt it. There are differences in the firmware code specific to each VIOFO Dashcam model, never mix and match!
BUT - it's possible to copy Image Quality values from A119 PRO firmware and paste into A119 V2. Thats basically what I'm working on now, comparing and capturing best IQ from all 4 DRVs to see if one has better quality, then modify for testing, using all the previously released firmware versions to identify the various functions. Should have something interesting very soon. So in a way your idea of PRO containing better IQ could end up being correct ! All 4 DVRs more or less all use the exact same IQ but the PRO is a little different. Happy MOD'ing.lol I will not. Just asking for fun.
sounds good. how much difference between 119 and 119v2? they are using same firmware right?BUT - it's possible to copy Image Quality values from A119 PRO firmware and paste into A119 V2. Thats basically what I'm working on now, comparing and capturing best IQ from all 4 DRVs to see if one has better quality, then modify for testing, using all the previously released firmware versions to identify the various functions. Should have something interesting very soon. So in a way your idea of PRO containing better IQ could end up being correct ! All 4 DVRs more or less all use the exact same IQ but the PRO is a little different. Happy MOD'ing.
correct, same firmware, difference is GPS mount and lens.sounds good. how much difference between 119 and 119v2? they are using same firmware right?
https://dashcamtalk.com/forum/threads/a119-firmware.22223/page-39#post-417711Other than giving the ability to turn of all beeps, is there any advantage it flashing from FW3.6 to FW3.91?
