From the feedback I am getting it would seem I am the exception not the norm with the heat. I don't think it did this when I first got it about a year or two ago.
Appreciate the feedback from all.
39-40c is just an average summer day here in houston. my two a119 cameras with no modifications have already survived 2 texas summers. i don't think you'll have any issue either.
as for the GPS lag, there's not much you can do about that. all dashcams have lag showing the speed. watch a few dashcam crash videos on youtube and you'll see it in most any video that has gps speed showing - they hit whatever, and it still takes a few seconds for the speed display to change down to zero.
Thanks for the feedback.
I may have been misunderstood. My A119 gets extremely hot and does fail to the point I can't hold it. I'm talking from experience. Perhaps it was a friday built one
🙂. I do wonder how many cars have their air con to cool the unit almost immediately something my car struggles with. My car is also outside all the time and faces the afternoon sun when parked at home which is usually the hottest time of the day.
Re gps I agree but with a previous dash cam it created a separate gps file so I could sync the time to match exactly. With the way the A119 does it I have to extract the gps data to get it to match the real world timing. To much effort required. It only really matters when I'm posting to youtube or doing some club track type work.
Save yourself the trouble. My A119S has endured 45°C + while parked and recording without air-conditioning, no heat related issues.
Great to hear it may only be my A119. My A119 is version 1 so perhaps there is a slight change in the inside and also note you are using a different lens system which may also have some impact on the heat issue I'm experiencing.
Even though you haven't had any problems, heat is one of the worst enemies of electronics. It is always better to run those items as cool as you can. Just a suggestion.
I agree. Unless the A119 is built to Mil spec then I expect it to have problems in heat. I am not bagging the product just in case some think that.
A prudent suggestion if considering electronics in general. These on the other hand are built for higher tolerances, I'd wouldn't expect the same from a Television or an AVR.
As I mentioned above I doubt the electronics are at Mil spec. The casing must be above average to withstand the heat though. It has kept its shape. Using Mil spec chips and design I would expect would be to costly. The
105deg C correction it appears they are rated to 70 degrees C capacitors are an attempt at reducing the temperature problem. Lithium batteries tend to expand in repeatedly high temperatures and can potential explode just ask Samsung. This is the reason my old dash cam is not in service anymore. I replaced the battery a couple of times but had to expand the casing for it to fit because it would swell!
@LateralNW
Close call is right- glad you made it through unscratched. I'm curious which recovery software you have? That info might be very useful to someone here someday
Thanks for the concern. Sure it was too close and I am at a loss as to why a semi was on this small road and pumping it along. The only thing I think that saved me from crashing was he was going uphill so he could stop quicker.. he also looked like he was running empty or light load.
The recover software I use is called EaseUS Data Recovery Wizard Professional. I also use the A119 to restore damaged video. I'm puzzled why some videos are corrupt even though the recovered video doesn't show any reason for the failure and was part of the drive not at the beginning or the end.
Apologies for taking the thread off topic.
edit - corrected temperature I thought the capacitors where rated at. They appear to be rated to 70 Degrees C not 105 Deg C as I had expected. On the upside they can also handle down to -40 Deg C!!!
