A119 last video are broken
Discussion in 'A119' started by luc4s, Jul 6, 2017.
  1. JamesDoe
    JamesDoe New Member
    16
    5
    Country:
    Italy
    Dash Cam:
    Gazer F117
    Got my A119 yesterday. Same problem - if it was recording when power is cut, the lights go out at once and the last file is corrupt and unplayable. No GPS mount.
    The memory card is brand new, I literally just bought and unpacked it.
  2. CaptureYourAction
    CaptureYourAction Well-Known Member Retailer
    1,521
    551
    New England
    Country:
    Dash Cam:
    DOD, Dome Technologies, VicoVation, Viofo
    Try powering it with a USB charger (phone charger) plugged into a wall outlet. Let it record for a minute or so, then pull the power and see if it acts the same.
  3. JamesDoe
    JamesDoe New Member
    16
    5
    Country:
    Italy
    Dash Cam:
    Gazer F117
    Thanks for the tip.
    I've been using a 2A wall charger all along. However, I assumed the caps take a dozen seconds to charge up, but upon further reading I've found out it's way longer (a couple minutes). If I let it record for 2-15 minutes, it shuts down gracefully more often than not, but not always. So far I'm unable to find the pattern or reason for the failures.
    Actually, it's not the last video itself that bothers me (seems that playing it in the cam repairs it?). It's the fact that all the settings are lost.
    Hey Viofo, why not save settings in EEPROM, or in a config file on the card? How hard could it possibly be to store 20 bytes of data in a non-volatile memory?..
  4. OCD Tronic
    OCD Tronic Well-Known Member Retailer
    634
    424
    Carson City, Nevada (USA)
    Country:
    Dash Cam:
    VIOFO A119S A119 G1W-S A118C2 More on Amazon & OCDtronic.com
    It sounds like you have both bad caps and a bad RTC button battery. You'll want to contact your seller for warranty replacement.
  5. JamesDoe
    JamesDoe New Member
    16
    5
    Country:
    Italy
    Dash Cam:
    Gazer F117
    The clock never gets reset, by the way. Only the other settings. So they do not seem to be powered by the same supplementary power source. It stands to reason that RTC chip would have its own power while the rest is managed by the main chipset.
    If I were to return it, I have to wait a month for it to ship back + another month for a replacement. Not the kind of time penalty I want to take even though you're probably right.
    If I let it run for at least 3 minutes, the success rate seems to be close to 80% (1 failure out of 5 attempts). Odd.
  6. OCD Tronic
    634
    424
    Country:
    Dash Cam:
    I had customer report re-updating the firmware fixed that behavior (when it wasn't quite the RTC)
    Re-update the firmware to 1.7 (or use the new beta 2.x)
    Be sure to reset the camera to factory defaults afterwards to flush out anything stuck
  7. JamesDoe
    JamesDoe New Member
    16
    5
    Country:
    Italy
    Dash Cam:
    Gazer F117
    It's running 2.06 out of the box, will look for 1.7, thank you!
  8. 5Cowbells
    5Cowbells Active Member
    122
    89
    Country:
    Dash Cam:
    A119 FW3.1, A119S FW2.0
    @OCD Tronic is thinking A119S. Latest A119 firmware is V3.1 at the Viofo support website.
  9. OCD Tronic
    634
    424
    Country:
    Dash Cam:
    Thanks got my A119/A119s threads mixed up.
  10. CaptureYourAction
    1,521
    551
    New England
    Country:
    Dash Cam:
    When selecting your settings, be sure to press the emergency (!) button to confirm the setting change before exiting back to the main menu. If you don't confirm with the ! Button, settings will default.
    viofo and jokiin like this.
  11. viofo
    viofo Well-Known Member Manufacturer
    560
    829
    Shenzhen
    Country:
    China
    Dash Cam:
    WR1/A119/A119S, A118C/A118C2, G1W-C/G1W-CB/G1W-S
    The settings should be saved every time.
    If lose date/time, it is the RTC battery issue, if lose settings, maybe other issue like capacitor.
    You can try upgrade firmware first.
  12. JamesDoe
    JamesDoe New Member
    16
    5
    Country:
    Italy
    Dash Cam:
    Gazer F117
    It's not the time, it's all the other settings that are lost. I've installed 3.1 firmware yesterday, it seems to have made a difference: the REC button light still may go out immediately instead of remaining on for a couple seconds after power disconnect, but I have not lost the settings during that incident! With 2.06, I would lose settings 100% guaranteed every time the REC light dies immediately. However, "after" does not mean "because of", maybe it's just a coincidence that behavior changed after flashing 3.1. I shall observe further.
    Thanks for the help / advice!
    viofo likes this.
  13. Zardoz66
    Zardoz66 Member
    74
    22
    Country:
    Dash Cam:
    VIOFO A119 V2
    hope this also helps
    [​IMG]
    [​IMG]
  14. JamesDoe
    JamesDoe New Member
    16
    5
    Country:
    Italy
    Dash Cam:
    Gazer F117
    After doing two dozen more power disconnect tests today, I'm positive that the problem no longer occurs, or its occurrence rate has greatly diminished. I'm speculating it's related either to the 3.1 upgrade, or to my resetting the settings to defaults prior to the upgrade.
  15. Leopold
    Leopold New Member
    22
    14
    Country:
    Sweden
    Maybe it could be related to the length of clips? I go by the 3 min setting which givs clips of max half a Gigabyte. Never seen a problem with corrupted last files but the larger the last file may be the larger the likelihood of a problem if the capacitors are not really specified for the more extreme file sizes.
  16. jokiin
    jokiin Well-Known Member Manufacturer
    35,058
    17,460
    Country:
    China
    Dash Cam:
    Too many ¯\_(ツ)_/¯
    file size doesn't matter, closing a 1 minute file or closing a 1 hour file is the same process
  17. Leopold
    Leopold New Member
    22
    14
    Country:
    Sweden
    Ok, great to know if I should run into trouble later on. Never seen the slightest sign of trouble yet, all files are recorded perfectly. I'm following this thread with great interest.
    jokiin likes this.
  18. OCD Tronic
    634
    424
    Country:
    Dash Cam:
    That Makes sense
Loading...
Share This Page
