MOD 6Nxv1 vs. 6Nxv2
Soft sharpness
Normal sharpness
Strong sharpness
Nxv1 is my choice.
1 is a bit warmer.
EXCELLENT !! this is the Best 24Mbps A119S Image Quality footage from all previous Stock or Modified Firmware, not counting the high Bitrate 27Mbps MODs. Thank you Sir for the time and effort to record all these clips under a variety of light conditions. Your Lens works well at Normal Sharpness but all 3 levels are acceptable and was my adjustment goal. Which A119S Lens was used for this footage? I especially like the Highway Tunnel clips.Today on the highway I did some videos with new stable firmware 4Vg.
Unfortunately we had no sunny weather, so it's cloudy, but I also tried to get some footage in a tunnel
The first half is 1920*1080 30fps in the afternoon on the highway and also in tunnel
Soft:
https://drive.google.com/open?id=1QbyjYiRYPVVxrjCnIUhlogBRcOkRoPb8
https://drive.google.com/open?id=1p05_n329WjgH9ulT8Y3cwviS6g6sg4Yf
dusk: https://drive.google.com/open?id=1dpX7Kt-xF7BC9aXIaUV8NHR-uIRnmGyI
Tunnel: https://drive.google.com/open?id=14-EuVIvjcghnBgG0pxvZZzSYJUhLbH_Z
Normal:
https://drive.google.com/open?id=1Dj3Z-N16RtEZnBfHX7cltVW6I1PeM59v
https://drive.google.com/open?id=1z9lN6uJIqfmiwkro8DVeBks2xM2GwbK6
https://drive.google.com/open?id=1ZoNsxCm6ouzoDkYXCFSMUTQHjPDnlthN
dusk: https://drive.google.com/open?id=1UFvjLAaAkIqP4IBJq4Wt70hL56i2Da9P
https://drive.google.com/open?id=1eDsHoPTaGFCksM6FHSPbpn77ecJ3rGkL
Tunnel: https://drive.google.com/open?id=1AGA0LM7uZhR_99jAmlmB3hgo4vXHlR0o
Strong:
https://drive.google.com/open?id=1FEFGuXmiOIP-dsHDWMqVY9R7uMLtPAaN
dusk: https://drive.google.com/open?id=1f8LvSGsdgApSaMydXOBFLAWz9seE1vBA
Tunnel: https://drive.google.com/open?id=1_8Z0-OoROSL6FFMS2ekjyAW9XnFFUvnn
The second half is 1920*1080 60fps and in dusk on the highway
Soft:
https://drive.google.com/open?id=1jcy24ibidiGpUTMFrHtnh_bOVuHsB8-C
https://drive.google.com/open?id=1MHuyoRbvt2HX1PMKU9QBp2hA9jE9cOAa
Normal:
https://drive.google.com/open?id=1ODgSa0Y3edeppgV56bpbBEbSUkQ76Svc
https://drive.google.com/open?id=1v0XLoxxA1INy7SNyLIAlb-tJnejwcqdr
https://drive.google.com/open?id=1lxk379BaeyXOUv1FIRV9Lz5-8txvUTpe
Strong:
https://drive.google.com/open?id=1XRbrkOAokaylRml-0_IFF_EYCENUzh1m
https://drive.google.com/open?id=1EHPfwZHJ8xVHDA8IBc9RxiReqVp8YXCq
FANTASTIC night footage from A119S V2 Lens2 using modified firmware 6Vh-vivid at 26Mbps with Soft Sharpness!!! Osborne Village never looked so good! The time and effort Beta testing is paying off just in time for the Holidays. Thanks for sharing this cold crisp clip.Here's a night clip from 6Vh-vivid.
Did I mention how much I like colour, saturation, and a warmer image? This is impressive! Makes you almost forget that it's cold outside and the sides of the roads are disgusting. If we could have gotten a 27Mbps bitrate this would look even more incredible.
1080p@30fps + CPL + WDR Off + EV 0 + 60Hz + Soft Sharpness
6Vh - Vivid - Night
Thank you [emoji4]EXCELLENT !! this is the Best 24Mbps A119S Image Quality footage from all previous Stock or Modified Firmware, not counting the high Bitrate 27Mbps MODs. Thank you Sir for the time and effort to record all these clips under a variety of light conditions. Your Lens works well at Normal Sharpness but all 3 levels are acceptable and was my adjustment goal. Which A119S Lens was used for this footage? I especially like the Highway Tunnel clips.
Last video clip file corruption FixThank you [emoji4]
It's lens 2 of my second Dashcam.
The first is still under repair at Viofo because of the broken video file when turning off the ignition, also again some weeks after changing the capacitors.
I know and my Dashcam is working almost every day.Last video clip file corruption Fix
Common issue when VIOFO Dashcam isn't used for 14-21 days if SuperCapacitors have failed and require replacement if memory card is removed while red REC button is still lit.
Suggest connecting A119/P/S to 5 volt smartphone/tablet charger indoors for 1 hour allowing it to record video on memory card, enable Parking Mode for testing to save storage space. The point is to allow Capacitors and tiny RTC battery to charge (RTC normally takes 4 hours). After that power cycle dashcam by disconnecting power cable waiting 12 seconds then reconnecting power cable.
Remember to watch the REC button light to see if its staying on 4-6 seconds longer after disconnecting power cable.
Always wait 5 seconds for red REC button light to go off before ejecting or inserting microSD memory card.
Viofo A119S - parking mode doesn't work | A119S | 1 | ||
R | VIOFO A119S let me down. | A119S | 3 | |
M | VIOFO A119S - screen | A119S | 11 | |
New VIOFO A119S arrived. First glance screenshots | A119S | 25 | ||
VIOFO A119S Screen Broken? - No video signal | A119S | 10 |
