Dcuellar90
- Feb 23, 2019
Thank you all for your help and replies.
Can you clarify this statement? What do you mean by “the hardwire isn’t connected to any fuses”? What have you connected the red and yellow wires to?The hard wire isn't connected to any fuses. The red is connected to constant power yellow accessory is connected and no power when the car is off and ground is connected
YesAre you running firmware V1.5?
I'm running into the same problem with mine. How did you end up fixing yours?
All wires need to be connected for the 3-wire kit to work.Looks like my issue is different then. Both motion detection and parking mode is off. I'm going to see if I can't just hardwire it with the ACC wire and not hook up the the always on one.
Yeah, I just tested it before seeing this. I'm not sure what else to do besides hoping to remember to turn it off when I turn off the carAll wires need to be connected for the 3-wire kit to work.
What exactly is your issue?Yeah, I just tested it before seeing this. I'm not sure what else to do besides hoping to remember to turn it off when I turn off the car
I have the dual A129 dashcam. I just finished installing it yesterday in my 2019 Jeep Cherokee with the hardwire setup. Using fuse taps, I've plugged the ACC wire into the "Washer Pump Front" fuse slot and always on wire into the "Deadbolt All Unlock" fuse slot. When I turn off the vehicle, the camera stays on despite ensuring motion detection and parking mode are both off.What exactly is your issue?
Did you measure for voltage at the washer pump fuse after the car was shut off? Just because your washer pump doesn't work when the car is off does not mean the fuse isn't still powered. They are probably all computer controlled. Check that first with a meter.I have the dual A129 dashcam. I just finished installing it yesterday in my 2019 Jeep Cherokee with the hardwire setup. Using fuse taps, I've plugged the ACC wire into the "Washer Pump Front" fuse slot and always on wire into the "Deadbolt All Unlock" fuse slot. When I turn off the vehicle, the camera stays on despite ensuring motion detection and parking mode are both off.View attachment 47069
I'll need to get an actual voltage reader then. I tried using just a straight circuit tester, but it lights up for every single interior fuse when the car is off.Did you measure for voltage at the washer pump fuse after the car was shut off? Just because your washer pump doesn't work when the car is off does not mean the fuse isn't still powered. They are probably all computer controlled. Check that first with a meter.
Also, be sure you have power going into the camera itself, not through the mount. Must be running firmware V1.5 or later as well.
