ungus
@viofo @VIOFO-Support
I've had the A139 3CH for almost a year now. It was working fine until yesterday. I turned on the Wi-Fi, the blue light came on, said "Wi-Fi enabled", then after a second, the [Wi-Fi] light turned off. Now the [Rec] light blinks, and the [Mic] light is solid while the unit beeps.
I powered it down, removed the SD Card and formatted it as FAT32, and tried again, with the same result. [Rec] light blinking, [Mic] light solid and beeping.
I bought a VIOFO and SanDisk Extreme card yesterday, formatted them to FAT32 and have the same issue with them as well.
I reset it to factory defaults (using both reset methods, button combination and the reset pin hole). It boots up as normal and says it's recording (using any of three SD cards I have). But once I enable Wi-Fi, it does the same as mentioned initially. States Wi-Fi is enabled, then immediately turns off, and it's back in the loop of [Rec] light blinking, [Mic] light solid and the unit beeping.
Thanks for your time
