chizzle36
Hi all, new member here. I just recently purchased the A229 and hardwire installed it into my car to take advantage of the dash cams parking mode capabilities. These are the settings I'm currently using:
Bitrate: high
Loop Recording: 3 minutes
WDR: off
Parking Mode: time lapse, 3fps, recording 24 hours
Motion Detection: medium sensitivity (though don't think this matters given my parking mode setting)
G Sensor: high sensitivity
Memory card: 256 gb Sandisk High Endurance
Post-installation testing seemed to suggest everything was working fine. Dash cam turns on upon starting up the car and immediately switches over to parking mode. I am currently on Day 2 post-installation.
Here are the issues I've run into and wanted to see if the community has any sense of what's going on:
1. When I went to go to my car this morning, the lights were all on indicating that it was still recording, but I was not able to access the screen to check if it was still in parking mode. I hit the Wifi button, which has usually worked to get it out of standby mode and there was no response. I hit the menu button and the exclamation button and there was no response. I had to restart the dash cam to get it working again. I then took the car out and drove about 20 min and parked and it happened again. I wasn't able to get the screen out of standby mode, though the buttons seemed to be responsive this time (was able to "save" a video, but couldn't see anything on the screen).
2. As you can see from my settings, I have it set to record for 24 hours in parking mode. However, upon checking my memory card, it appears it stopped recording around 11:40pm last night, even though it went into parking mode only 5-6 hours prior.
3. I "saved" one of my parking mode videos from my drive today and it is glitching (see attachment). It glitches like that every few seconds in the video. I don't see this glitch on any of the other videos on my card.
Note, I live in NYC and street park with little to no shade where my building is. It has been in the 90s today and yesterday, so I'm curious if the heat has anything to do with these issues.
Any thoughts? Suggestions?
Bitrate: high
WDR: off
