Mtz
- Nov 15, 2012
- Nice place
- Romania
- Viofo A229 Pro TeleQuad (the best dashcam in the world!)
Be mindful when using an OTG adapter that the camera will be drawing power from the phone, which not all phones support so it's best to check first.Thanks for the idea! Certainly easier than trying to remove the micro SD card and plug it into your phone (if your phone even HAS a microsd slot - fewer and fewer phones do these days). And it's much harder to lose a cable than a micro SD card!
Btw that adapter you have is called an OTG (on the go) adapter. It lets you plug in things like thumb drives keyboard, mouse, etc. I have an OTG adapter... Never occurred to me to just plug the cam directly to the phone that way!
Edit: just found this: https://www.amazon.com/gp/B018M8YNDG
I think I'll order a couple to keep in my glovebox and desk drawer.
I don't know if you already found out how this works or not but here it goes anyway:Also...
If I press this button whilst in record mode (what is "video mode"), I just save a file. How do I access the playlist on the device itself?
I just checked for buzzing source...
Lens housing is 3-4mm from screen so no buzzing from that.
Right angle mini-USB a little loose so I put a little insulation tape inside one side of female socket. That's tight now.
I checked the buttons. The lower ones do rattle...
https://photos.google.com/share/AF1...?key=NG9BdVY0TThQelhxbmxJbnlsVXdBZUVJOEhWdUNR
...when I'm out today I will drive some distance to see if the mini-USB tape has worked.
If not, I have some tape to stick over the buttons to hold them in place.
You could try slipping an adhesive backed EVA foam pad ( like the ones included with the GC) in between the mount and camera for a snugger fit.
Only on bad roads??? U know what, I think u have a loose connection inside ur cam. Do this when ur parked and ur cam is recording try to lightly tap ur cam to imitate a bumpy road. But I do think something is loose inside ur cam. Return it and repurchase a new one. Problem solvedI have it mounted connected behind the fuses pannel, do you have a link for the cable you mention?
As for the interfference I only have it on bad roads.
When you turn it on without a card in, for instance. Every dashcam films without recording, you know?@Module 79L - when is cam filming but not recording?
I put my money on the buttons.It's the mount.
Lol, I'll have to buy an Euromillions ticket this week!...and the winner is...
- Tape in USB right angle connector socket = no difference, buzzing still there.
- Tape over lower three "raptly" buttons (see video clip in post #104) = buzzing disappears completely.
- Tape over buttons removed. Padding between camera and mount (grey Viofo 3M cut into narrow strips, either side of cam) = buzzing less, but still there.
You don't. I had to do the same to both the G1W-H and the At11DA. It's the easiest and quickest way. I used UHU clear tape: it's thin and flexible and it's almost invisible.So, how do I stop the buttons buzzing without a strip of insuation tape over them?
Do all dash cams need user modifications?
[*]Tape over buttons removed. Padding between camera and mount (grey Viofo 3M cut into narrow strips, either side of cam) = buzzing less, but still there.
