David.... toooo much dash left side compared to right side which leads me to believe when u installed it u did not rotate the whole cam so its levelFor CRYING OUT LOUD --- the cam is located to the right of the mirror...
Look at the front wings in post #71!! Perfectly in the middle of the frame, and the rear of the bonnet almost perfectly level.
AND... it's not up and down the lens adjustment to get more dash to one side, it is left and right the lens adjustment!
...I know you're just kidding me.![]()
Also for ur electrical interference u need to get another power cord similar what the Street Guardian uses on their cams . I t has 2 condensers one at each end so there is absolutely no magnetic or noisy interference Speak to @jokiin he will hook u up.David.... toooo much dash left side compared to right side which leads me to believe when u installed it u did not rotate the whole cam so its level
When u stuck cam to windshield U did not twist it by looking at the screen so the dash would be the same depth on both sides, its not a big deal but if u want it 100% perfect u need to redo it. No problem if u leave itAlso for ur electrical interference u need to get another power cord similar what the Street Guardian uses on their cams . I t has 2 condensers one at each end so there is absolutely no magnetic or noisy interference Speak to @jokiin he will hook u up.
POWER CORD POWER CORD TRY IT WITH UR FM RADIO ON SEE WHAT HAPPENSSecond clip uploaded, with more buzzing, if anyone can be bothered to listen and diagnose some more?...
Your cam seems to be perfect now as far as ur dash but in photo its different but in the footage it is perfect just the noisePOWER CORD POWER CORD TRY IT WITH UR FM RADIO ON SEE WHAT HAPPENS
This is handy... I found my Samsung S7 micro-USB-to-USB adapter. Used the video cable I found and this to plug the A119 into my S7 and immediately it went into mass storage mode and all the files appeared on my S7.
B | Bought a Viofo A119 with GPS v2 | A119 | 6 | |
D | Bought new a119 GPS. | A119 | 5 | |
B | just bought a VIOFO A119 | A119 | 7 | |
S | just bought new memory card for my A119- what should I do for best results? | A119 | 5 | |
W | Just bought A119 | A119 | 7 |
