Optional Manual User Configuration Setting Procedure
If a GUI tool is not available for your computer or you would rather just edit the configuration text file manually, it's easy to do, just follow these steps
exactly:
1.
Download the camera's configuration file to the flash card in the camera (HOLD DOWN MODE BUTTON, THEN ALSO HOLD DOWN POWER BUTTON UNTIL THE RED LED BLINKS 3 TIMES).
2.
Turn the camera on, connect it to your PC, and access the camera root directory when it goes into the "removable disk mode".
3.
Open the "SYSCFG.TXT" config text file with a simple (ASCII) text editor (e.g. the familiar "Notepad" text editor for Windows users). The file will look similar to this
ate time=[
2013/06/28-21:33:34];date time setting,format yyyy/mm/dd hh:mm:ss
Video Mode 1 resolution=[
0];Movie resolution setting,
0:1080p,
1:720p
Video Mode 1 Frame Rate=[
2];Movie frame rate setting,
1:60fps (only for 720p),
2:30fps
Video Mode 2 resolution=[
1];Movie resolution setting,
0:1080p,
1:720p
Video Mode 2 Frame Rate=[
1];Movie frame rate setting,
2:30fps
Photo Mode Capture Size=[
0];set photo size,
0:2304x1536,
1:1920x1080,
2:1280x720
Set Time Lapse Shooting=[
0],
0ff,
1:0.25s,
2:0.5s,
3:1s,
4:2s,
5:5s,
6:10s,
7:30s,
8:60s
Movie cycle time=[
2];movie cycle time,
0:3 minutes,
1:5 minutes,
2:10 minutes,
3:15 minutes,
4:max to 4G byte,
Movie Loop Recording=[
0];set loop recording on or off,
0ff,
1n,
Time stamp=[
1];set date/time stamp on or off,
0ff,
1n,
Movie sound=[
1];set movie sound,
0:mute,
1n,
Movie Flip=[
0];set movie rotate,
0ff,
1n,
Movie quality=[
1];set movie quality, set movie data rate,
0:Super,
1:Standard,
2:Low,
Movie high dynamic range=[
0];set movie high dynamic range,
0ff,
1n,
Power on=[
1];set system power on time,
0:delay,
1:fast
Power off=[
1];set system auto power off time when system pending,
0ff,
1:30 seconds,
2:1 minutes,
3:2 minutes,
Auto Record=[
0];set connect or disconnect with power to start or stop video recording automatically,,
0ff,
1n,
LED=[
1];set LED flicker when recording,
0ff,
1n,
Charge from USB Host=[
0]; when connecting with USB host, charge camera or not,
0n,
1ff
TV out=[
0];set Tv out,
0:NTSC,
1AL,
TV Display Ratio=[
0];set display ratio,
0:4*3,
1:16*9
{TLCAM MOV:2013/06/25 v0.32}
{LDTLCAM,v001}
Note: Values used by the camera shown bolded in the square brackets. Functions shown may vary with firmware updates, but manual editing is similar. Text in curly brackets at the bottom show the firmware and boot loader versions in the camera.4.
Replace any number(s) in the square brackets with any valid alternate setting number, shown highlighted to the right of each function. For the date and time, don't delete the dash (-), slash (/), or colon
) marks or add any spaces or invalid numbers.
You can keep the camera's current date and time if you use a question mark (?) for each number, i.e. [????/??/??-??:??:??] will keep the camera's current date and time.
NOTE: Except for certain functions which cannot co-exist, invalid numbers or other characters in the square brackets has not shown to cause serious problems. The camera appears to ignore them or switch to default values.5.
Save the revised file back to the memory card root directory, but do not change the file name.
6.
Upload the revised configuration back into the camera. The same key-press sequence used to download the configuration from the camera will also upload it to the camera.
7.
When the LED turns off, you're done! The new configuration will be in the camera and the config file will be automatically deleted from the flash card. You may check the flash card to confirm this if you wish.
