Anyone successfully using a UPS(Universal Power Supply) ?
Andy Moore
Anyone successfully using a 12v UPS wired between their battery and their dash cam for parking mode ?
Idea is that the UPS takes over from car battery at a certain voltage during Parking Mode and is re-charged by the car's alternator.
If so, which UPS are you using and what size ?
Thanks for that, will have a good read - looks promising
the best option - Power Magic Pro
I disagree and I'm already using a better low power cutoff than the Power Magic Pro
it is your right. The taste and color of comrades no.
Can't remember make but has much more voltage options than the Power Magic Pro
I'm looking for a good solution, a UPS - Cellink B looking best option available but costly. Can't see why cant simply connect camera to a separate battery & have a split-charge relay charging this battery from the cars alternator. Perhaps this is too simple a solution ?
better solution if you're fortunate enough to have room for a second battery
I'm using a powerbank: 10.000mAh, Output: 12V. I can use my dashcam for about 6-8hrs
